2010-08-24, 16:28
2010-08-25, 00:13
BurningSky Wrote:Download the .zip file from github.com (you can find the link in Eisbahn's signature) and install it like a normal addon (System --> Add-ons --> install from zip file/Aus ZIP Datei installieren).
ive tried it that way but it didnt work
do i need any other addons first in order to install a addon from zip?
i have downloaded the dharma addon file and in xbmc i then choosed install from zip -> locate the zip file and confirm
but after that addon is still not installed
2010-08-25, 07:19
Take a look at ~/.xbmc/addons/ is there a folder called metadata.imdb.de ? If not extract the zip file by hand.
2010-08-25, 08:10
hmm scraper doesnt work for me
it always crashes xbmc when adding a new source directory and looking up film informations for Dorm Daze 2 (2006) ... dont know why --> http://www.imdb.de/title/tt0458438/
all movies up to this are working fine but when retrieving informations for dorm daze 2 it crashes
maybe it doesnt like the film
normal imdb scraper is working fine
2010-08-26, 18:37
Hi, i tested the Scraper, but now my movies are not alphabetic sorted.
I think many Movies show " as first Letter.
2010-08-31, 06:37
Hmm rating tag is broken here. ( i somehow get different numbers than the one from imdb.de, for example 9 Votes instead of 52.000 Votes for "8 Blickwinkel" and a wrong rating also of course)
I also don´t get any certification (Altersfreigabe) tag. Is that intentional?
Apart from that, great scraper Will probably be the first integrated scraper I use, atm i still manage my library with ember media manager. would really be great to be able to manage everything inside xbmc.
2010-09-02, 17:33
Quote: Hi, i tested the Scraper, but now my movies are not alphabetic sorted.It's a problem with the sorttitle.
It actually has this "..." format and is of course sometimes
different from the actual movie-title.
For a quick and dirty workaround just delete this from the imdb_de.xml
(the commentary of course doesn't matter)
<!--weitere/alternative Filmnamen außer Originaltitel (benötigt in $$5 alle in Frage kommenden Filmnamen)-->
<RegExp input="$$5" output="<sorttitle>\1 \2</sorttitle>" dest="4+">
after that everything is sorted alphabetically by the title again,
so that renaming also will work.
2010-09-04, 16:22
hey
xbmc crashed bei dem versuch den content zu aktualisiern. direkt beim ersten video.
wäre super wenn du das updatest
2010-09-04, 23:02
This is an english forum.
2010-09-05, 09:21
Hi folks,
sorry for being not present in the forum for the last weeks, but had a bad injury after a motorbike crash.
Think on the next days/weekend I will have time to check all the supported tags and release a new version which uses the common functions. Maybe you can install after that procedure the scraper straight forward from the original repository.
Regards,
Eisbahn
Regards,
Eisbahn
2010-09-05, 13:28
Dharma crashes because of the scraper
good betterment
good betterment
2010-09-05, 19:48
Squizzy Wrote:Dharma crashes because of the scraper
good betterment
- what movie/filename?
- what versions and OS are you using?
- Link to Logfile on pastebin or similar <http://wiki.xbmc.org/index.php?title=HOW-TO_Submit_a_Proper_Bug_Report>
I remember crashes with older versions and special chars in filename...
2010-09-06, 17:28
Movie: Max Payne 2
XBMC: Dharma Beta
OS: Windows 7
PC:
No Crashlog by XMBC, but Windows post something!
http://pastebin.com/GwELLydc
Hope that it helps you
XBMC: Dharma Beta
OS: Windows 7
PC:
- Intel Q6600
- 4GB DDR2 Ram
- GeForce 250GTS
- 1TB HDD
2010-09-19, 17:00
new version online: http://github.com/Eisbahn/IMDb_de-Scraper/zipball/3.0.5
But: still crashes (sometimes) of XBMC on some movies e.g.
Dod Sno (2009)
Dorm Daze 2 (2006)
Max Payne 2 (2008)
reported from several users.
XBMC Log shows "normal" working of the scraper and stops after some time (in the middle of scraping) . Some experienced programmer should have a look at this...
Regards, Eisbahn
Dod Sno (2009)
Dorm Daze 2 (2006)
Max Payne 2 (2008)
Regards, Eisbahn
2010-09-28, 06:41
is it possible to include the original tagline instead of the first sentence of the plot?
