Full Version: German IMDB scraper, please test it and give feedback
Pages: 1 2 3 4 5 6 7 8
bugfix Version 3.1.1:
- fix nfourl lookup with uppercase imdb url (titel, year and rating missing on autoscan)
- more caching (imdb.com link to moviemaze)
the scraper: metadata.imdb.de-3.1.1.zip
the repository addon: repository.gropp.org.imdb.de.zip
trackel
Hey,
is it possible to add an option to keep the original title from IMDB.com ? I'd like to have the plot outline in german, but the title shall remain english because translations suck most of the time.
Other than that: good work! Big Grin
that was kinda easy Wink
Version 3.1.2:
- added plot from tmdb
- added title from imdb.com
the scraper: metadata.imdb.de-3.1.2.zip
trackel
Wow, didn't expect that to happen so quickly!
Big thanks for this scraper, I like it alot!
But it seems to have sometimes problem for me finding the correct movie. Maybe I am doing something wrong or there is a setting that I missed.
For example a file named "Avatar (2009)". It fetches this as a result http://www.imdb.de/title/tt0497595/.
Also "The Champ (2007)", delivers this http://www.imdb.de/title/tt0325164/.
I dont understand since the names are quite clear and the year seems to get just ignored.
This is the xbmc.log for the scrapes:
Avatar
The Champ
Thanks for any hints!
Even when I really like your scraper, I personally think the posters (covers) from videobuster are the best (as they are german too). Therefor, it would be a great benefit for this (german) scraper to use the posters from videobuster.de
@devkid: this is a problem with the imdb search engine. You can fix it using .nfo files with a correct imdb url or using the full movienames as folder
@Anira: i have no idea how to link from imdb to videobuster. If you have any clue how to get the correct videobuster url using imdb i can look into it
Hi all,
the german imdb scraper 3.1.2 doesn't work well anymore .. no plot .. no fsk (age rating). Could some skilled person look into this please.
**edit: probably my mistake .. ignore please if I don't follow up**
Just starting with Eden Beta ... and the imdb.de scraper doesn't work. It sais it fails to connect to server. Does anyone else experience this?
Edit: Went through the includes list in the scraper xml and now that I have all includes present it works.
Eisbahn/trackel, thank you for this scraper!
It works well for me with specific IMDb id search (see http://forum.xbmc.org/showthread.php?tid=120707). I wondered why some movies weren't found. There are rare cases where the year isn't [0-9]{4} but there is an additional '/I' suffixed. This has to be changed in GetSearchResults. GetDetails works accidentally ;-)
Examples:
<meta name="title" content="Armageddon - Das j&#xFC;ngste Gericht (1998/I)">
<meta name="title" content="Der Kautions-Cop (2010/I)">
Debug:
22:07:20 T:2752   DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'E:\Filme.HD\The Code - Vertraue keinem Dieb (2009) [tt1112782].mkv'
22:07:20 T:3060   DEBUG: Thread CVideoInfoDownloader start, auto delete: 0
22:07:20 T:3060   DEBUG: ADDON::CScraper::FindMovie: Searching for 'tt1112782' using IMDb.de scraper (path: 'C:\Users\MediaPortal\AppData\Roaming\XBMC\addons\metadata.imdb.de', content: 'movies', version: '3.1.2')
22:07:20 T:3060   DEBUG: scraper: CreateSearchUrl returned <url>http://www.imdb.de/find?s=tt;q=tt1112782</url>
22:07:20 T:3060   DEBUG: FileCurl::Open(002FD338) http://www.imdb.de/find?s=tt;q=tt1112782
22:07:21 T:3060   DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="iso-8859-1" standalone="yes"?><results></results>
22:07:21 T:3060   DEBUG: ADDON::CScraper::FindMovie: Searching for 'tt1112782' using IMDb.de scraper (path: 'C:\Users\MediaPortal\AppData\Roaming\XBMC\addons\metadata.imdb.de', content: 'movies', version: '3.1.2')
22:07:21 T:3060   DEBUG: scraper: CreateSearchUrl returned <url>http://www.imdb.de/find?s=tt;q=tt1112782</url>
22:07:21 T:3060   DEBUG: FileCurl::Open(002FD338) http://www.imdb.de/find?s=tt;q=tt1112782
22:07:21 T:3060   DEBUG: Thread CVideoInfoDownloader 3060 terminating
I used this scrabber sucessfully for a long Time. But view weeks ago, it stops working. I found som reason in the Search-URL wheres the API seams to hafe chaged. it has to be s=tt&p=... and not s=tt;p=... but that seams not to be tha only changes. The scrabber dosent find the results in the HTML-Result even with the bodified search-URL.
Is it planed to fix the Problem?
Can I do som firder Help?
i finally put the repo with my changes online on github: https://github.com/vgropp/IMDb_de-Scraper
Still no fixes about the issues with "(2012)" and the api change (havnt it noticed yet) as my setup seems to work fine. Maybe some of you can test it further and send pull requests or patches or more hints?
trackel
undefined
undefined
undefined
undefined
hallo trackel
besten dank für deine arbeit, jedoch ist auf https://github.com/vgropp/IMDb_de-Scraper keine neue version zu finden, oder ich bin zu doof.
was meinst du mit dem (2012) fehler?
