Full Version: Specials but title and plot are not being displayed
Recently, I moved a number of Tv-based movies (futurama, simpsons, firefly) from my movies section to specials section within each appropriate show. They are named properly (s00exx) and the tvdb scraper does pick them up as specials, but the plot and title of each does not display in xbmc or was not scraped even though it is present in the tvdb database. Does anyone have any ideas. The files are located within a "specials" folder within each shows parent directory.
Thanks,
EdgesitterBig Grin
What happens when you 'Refresh Information'?
The refresh occurs with the same fanart for the episode but no plot or title, just season/episode xx
You got any 'rogue' nfo files from a previous failed or incomplete scrape (either by xbmc or a 3rd party scraper) which might be getting used instead of the fresh information? Check and if so removing them and rescraping shoud get the 'new' information.
Otherwise a debug log should be provided - see here http://forum.xbmc.org/showthread.php?tid=42708
