Hi
I was wondering if there is a script that you can point to a custom folder(trailers) with moviename-trailer.mov files in it and when you go to a movie and press info then trailer button it plays it. basicly a script for custom trailer folder.
thanks
you can put a trailer in the same folder as your movie and it will be available as the trailer when you select the "trailer" button in the movie info screen (some other places in some skins)
It needs naming something specific (cant remember what) something like movie-trailer.avi
best looking at the media companion thread for mention of it.
Summery - no script needed, its a feature of xbmc.
Thanks but i already new that. Im using that option now. i just want one single folder for trailers. like you would for cdart
Im in the process of re-writing my YouTrailer script and plan to add support so users can add custom folders for trailers etc.Well, after reading your post I now plan on adding it
Keep an eye on progress here:
http://forum.xbmc.org/showthread.php?tid=69593
Maybe even re-post your idea there to remind me
hehe
