2010-06-05, 20:53
First of all I have to say NICE one. This is perfect for my home setup.
I have 2 XBMC systems that are on all the time.
XBMC in my front room is utilized all the time and is my main multimedia system but sometimes i would like to move to bedroom and not have to go all the procedure of stop it on the front room and than go to the bedroom select the video and forward aprox to the place i left it of.
On the android remote i can see that it is precise on the play position of "now playng".
I am not a developer so here is my question:
Is there a chance that you can have a option under the now playing options to transfer to other xbmc. This is if you have the xbmc databases are identical.
In one way i am thinking is get play timer on xbmc1 and connect to the XBMC2 and play from play timer of the XBMC1.
Can this be an option or a future feature?
Thank you.
Thank you.
