Full Version: crash on 9.10
dear all,
I installed xbmc on ubuntu 9.10 (4850e+k9n sli platinum + hd4670) but often it freeze and i don't know why. it happens in different situation, sometimes when i try to exit xbmc or during the scan of the hd. here one of the log.
http://pastebin.com/KcJUkvvW
can you help me to find a solution?
no one?
for more info, I got same problem with boxee. only when I tried to exit the program
Try upgrading XBMC to dharma.
done.
seems to work.
another question: the scraper put tv show (with wrong name) in the folder of the movies. how can I fix the problem? what's the best way to organize the folders?
tnx
EDIT: freeze again when I refresh the music archive.
bump
problem solved with upgrade to 10.04
tnx to all
