Full Version: Library disabled
I cannot get the Library mode to work. Not on my video's and music either.
The Library Mode is disabled on the left of the screen.
I've cleared the library, scanned the music folder again to the library, but nothing helps.
Edit:
I know now what the problem is, the databases are in a wrong version (looking at the log file).
But if I delete the databases, and start XBMC it freezes, log file:
18:02:48 M: 48910336 NOTICE: load default skin:[Project Mayhem III]
18:02:48 M: 45719552 ERROR: SQLite: Some kind of disk I/O error occurred
Query: PRAGMA default_cache_size=16384
18:02:48 M: 45719552 ERROR: CViewDatabase::CreateTables unable to create tables:1117
18:02:48 M: 45719552 ERROR: SQLite: SQL error or missing database
Query: SELECT idVersion FROM version
18:02:48 M: 45719552 FATAL: Unknown exception code (0xe06d7363)
at 0x000d5a52
And the only way to get XBMC working again is to restore the old databases (from a backup).
But then the log file looks like this:
18:06:54 M: 49442816 NOTICE: start fancontroller
18:06:54 M: 48910336 NOTICE: load default skin:[Project Mayhem III]
18:06:55 M: 45780992 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
18:06:55 M: 45715456 NOTICE: Attempting to update the database MyVideos34.db from version 21 to 33
18:06:55 M: 45756416 ERROR: SQLite: The database schema changed
Query: select count(1) from movie
18:06:55 M: 45756416 ERROR: CVideoDatabase::HasContent failed
18:06:55 M: 45735936 ERROR: SQLite: Some kind of disk I/O error occurred
Query: UPDATE version SET idVersion=33
18:06:55 M: 45735936 ERROR: Can't update the database MyVideos34.db from version 21 to 33
18:06:55 M: 45215744 NOTICE: CApplication::UpdateLibraries - Starting music library startup scan
18:06:55 M: 45195264 NOTICE: Attempting to update the database MyVideos34.db from version 21 to 33
18:06:55 M: 45195264 ERROR: Control 402 in window 10112 has been asked to focus, but it can't
18:06:55 M: 44945408 NOTICE: Attempting to update the database MyMusic7.db from version 10 to 14
18:06:55 M: 44814336 ERROR: SQLite: Some kind of disk I/O error occurred
Query: CREATE TABLE karaokedata ( iKaraNumber integer, idSong integer,
