2010-06-06, 23:03
hi,
Xbmc (9.11) after Ubuntu mini install (9.10 x86_64)
Zotac ION 330 (a hell of a motherboard :p)
I've managed (after several hours) to get my Terratec Cinergy Hybrid T XS USB recognized by v4l and LIRC. I'm just using the IR part of this device as the rest of it seems to be dead. Anyway, LIRC is reading all the keys perfectly, but I can't managed to get XBMC response to them except from some standard keys like play/pause stop, vol+ vol- etc...
Could there be a reason for that ? I've set up my Lircmap.xml like that :
It resides under /home/xbmc/.xbmc/Lircmap.xml
EDIT : indeed, it is in /home/xbmc/.xbmc/userdata/Lircmap.xml
Do you see something wrong I didn't ? I didn't change so much the remote.xml unders /usr/share/xbmc/system/keymaps/remote.xml
PS : I already found some usefull topics like
http://wiki.xbmc.org/index.php?title=HOW...lk_to_XBMC or http://forum.xbmc.org/showthread.php?tid=45972 so it seems useless to indicate me those I also found another thread which has a title like seems to be like my issue but that doesn't solve it...
Thanks,
LTourist
FINAL EDIT : Solution
Ok, If like me you are looking for a solution for this annoying problem, here it is :
Don't forget to set START_LIRCD="true" in the /etc/lirc/hardware.conf file. This is not the way the configuration is initially, but this is NECESSARY to really start the daemon and so enabling XBMC to talk with LIRC
See ya!
<lircmap>
<remote device="HybridTXS">
<display>KEY_HOME</display>
<power>KEY_POWER</power>
<menu>KEY_MENU</menu>
<one>KEY_1</one>
<two>KEY_2</two>
<three>KEY_3</three>
<four>KEY_4</four>
<five>KEY_5</five>
<six>KEY_6</six>
<seven>KEY_7</seven>
<eight>KEY_8</eight>
<nine>KEY_9</nine>
<zero>KEY_0</zero>
<subtitle>KEY_SUBTITLE</subtitle>
<teletext>KEY_TELETEXT</teletext>
<recordedtv>KEY_DELETE</recordedtv>
<language>KEY_LANGUAGE</language>
<star>KEY_AB</star>
<mytv>KEY_TV</mytv>
<livetv>KEY_DVD</livetv>
<myvideo>KEY_VIDEO</myvideo>
<mypictures>KEY_PICTURE</mypictures>
<up>KEY_UP</up>
<left>KEY_LEFT</left>
<right>KEY_RIGHT</right>
<down>KEY_DOWN</down>
<select>KEY_OK</select>
<guide>KEY_EPG</guide>
<info>KEY_INFO</info>
<back>KEY_BACK</back>
<volumeplus>KEY_VOLUMEUP</volumeplus>
<volumedown>KEY_VOLUMEDOWN</volumedown>
<channelplus>KEY_CHANNELUP</channelplus>
<channeldown>KEY_CHANNELDOWN</channeldown>
<red>KEY_RED</red>
<green>KEY_GREEN</green>
<yellow>KEY_YELLOW</yellow>
<blue>KEY_BLUE</blue>
<record>KEY_RECORD</record>
<mute>KEY_MUTE</mute>
<play>KEY_PLAY</play>
<stop>KEY_STOP</stop>
<pause>KEY_PAUSE</pause>
<skipminus>KEY_PREVIOUS</skipminus>
<reverse>KEY_REWIND</reverse>
<forward>KEY_FORWARD</forward>
<skipplus>KEY_NEXT</skipplus>
</remote>
</lircmap>
Thanks,
LTourist
See ya!
