^^ Interesting. I tried using Paragon Drive Utilities last night and it kept spitting out 6GB backups for one XBMC install! I'm going to give clonezilla a try now.
Keep in mind that my image contains three bare installs. Meaning no library or thumbnails folder. I imagine fanart for a large movie collection would be substantial.
cheers
hmmmmm.... You are right! I didnt think about that. I wish removing the revo's hard drive wasn't such a PITA. I'll just connect another hard drive via the e-SATA port and do a fresh install there, which I'll use to create the image.
Thanks guys I'm getting CPU/GPU 48/43 after 30 minutes of Avatar. (40GB version)
Also it's completely silence now with the Sharkoon Silent Eagle SE. That was the reason for me to mod it.
The passive cooler is from a old Wyse Citrix client and needed a lot of cutting before it fitted in.
I'm using a Class 10 SD card and removed the internal HD and wireless module to reduce heat.
WOW! Extremely impressive. I an not sure I'd want a fan like that stuck to the revo however
Any reason you want it to be so cool?
No particular reason, just wanted it to be completely silent.
Kinda never expected it would work so well and get so much better cooling even if I turn the Fan speed on the lowest setting
Hi!
I recently bought the Revo 3610 and for now I'm using MediaPortal on the Windows 7 HP that came pre-installed on my Revo, but I decided to try Ubuntu + XBMC.
I installed it to a USB stick and it works pretty well (Ubuntu itself is a little sluggish, probably because of the cheap, slow pendrive it's installed on, but movies play really well with VDPAU), however I'm not a linux guy and setting up the OS to utilize the full potential of the Revo kinda scares me
Has someone already posted a partition image with a fully setup XBMC? I read the thread and harryzimm was talking about posting his, but I don't think he actually posted a link?
Also, would it be possible for someone to post an image of their partition with OSX install?
I was actually supposed to post up an image but RL got in the way. I will try to get it done soon. hopefully
gribbler will forgive me
I'm still looking for an image with OSX on it also.
If you would like to do the install yourself, just follow the steps using the XBMCFreak installation USB. There is an option to install to hard drive. Simple as pie.
Yes I forgive you both - neither of you uploaded.. sheesh.
Yeah sorry, my upload speed is pathetic. The osx image was like 8gb, it would take days to upload. Im still playing with an ubuntu image, trying to get it as small as possible. I will post it but i might as well wait for dharma now.
cheers
you can toss it in the post if you like
Roelio Wrote:Thanks guys I'm getting CPU/GPU 48/43 after 30 minutes of Avatar. (40GB version)
amazing job, already PM you or anyone here to find the same heat sink !
anybody got idea will be good for me
someone showed me this for the little chip ( presume it's north bridge or somethin' )
http://www.grosbill.com/4-zalman_de_chip...eur_tuning
and this for CPU :
http://www.rueducommerce.fr/Composants/R...39-AM2.htm
with both i'll have a complete passive cooling system but don't have any idea on how to fix it whatever solution I'm choosng !
clovis86
That was the same idea I had, but making those fit will be hard I guess.. But you could always try
The main reason I used that Wyse 902163-01L heatsink was that I could manually drill mounting holes.
I talked with my supplier in Den Haag and he will send me two broken Wyse clients so if you like I could send you a heatsink from it
Greetings,
Roelio
woah définitely Roelio !
I would really appreciate it !
I'll send you a PM
I also found a way to put my current ubuntu 10.04 from HDD to SDHC : using Remastersys !
