Full Version: Can I disable the "Back a Level" icons in Library mode?
You know the ones I mean, the two dots ".." that take you back a level.
I'm sure I have disabled them before but after a reinstall I lost the settings.
I think it is an advancedsettings.xml command similar to the one for removing All Seasons but I can't find it for the life of me.
I use back on my MCE remote so they just make my library untidy.
they are called parent folder items and you can disable/enable in appearance settings.
Doh, I must have looked everywhere except there. Sigh.
Thanks Spiff.
