Full Version: Xbmc crash
Pages: 1 2
=====> Core file: /core
=====> Core file: /root/.xbmc/plugins/programs/SVN/core
=====> Core file: /root/.xbmc/plugins/programs/SVN Repo Installer/core
############# END STACK TRACE ###############
################# LOG FILE ##################
23:17:19 T:3025696624 M:937865216 NOTICE: -----------------------------------------------------------------------
23:17:19 T:3025696624 M:937865216 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Jun 10 2010 (SVN:exported)
23:17:19 T:3025696624 M:937865216 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
23:17:19 T:3025696624 M:937865216 NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
23:17:19 T:3025696624 M:937865216 NOTICE: special://home/ is mapped to: /root/.xbmc
23:17:19 T:3025696624 M:937865216 NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
23:17:19 T:3025696624 M:937865216 NOTICE: The executable running is: /usr/share/xbmc/xbmc.bin
23:17:19 T:3025696624 M:937865216 NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
23:17:19 T:3025696624 M:937865216 NOTICE: Setup SDL
23:17:19 T:3025696624 M:937095168 NOTICE: load settings...
23:17:19 T:3025696624 M:937095168 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:17:19 T:3025696624 M:937095168 NOTICE: loading special://masterprofile/guisettings.xml
23:17:19 T:3025696624 M:937095168 NOTICE: Getting hardware information now...
23:17:19 T:3025696624 M:937095168 NOTICE: Checking resolution 12
23:17:19 T:3025696624 M:937095168 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:17:19 T:3025696624 M:937095168 NOTICE: Loaded playercorefactory configuration
23:17:19 T:3025696624 M:937095168 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:17:19 T:3025696624 M:937095168 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:17:19 T:3025696624 M:937095168 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
23:17:19 T:3025696624 M:937095168 NOTICE: Default DVD Player: dvdplayer
23:17:19 T:3025696624 M:937095168 NOTICE: Default Video Player: dvdplayer
23:17:19 T:3025696624 M:937095168 NOTICE: Default Audio Player: paplayer
23:17:19 T:3025696624 M:937095168 NOTICE: special://masterprofile/sources.xml
23:17:19 T:3025696624 M:934436864 NOTICE: Using fbConfig[0]
23:17:19 T:3025696624 M:933167104 NOTICE: GL_VENDOR = NVIDIA Corporation
23:17:19 T:3025696624 M:933167104 NOTICE: GL_RENDERER = GeForce2 MX/AGP/SSE2
23:17:19 T:3025696624 M:933167104 NOTICE: GL_VERSION = 1.5.8 NVIDIA 96.43.17
23:17:19 T:3025696624 M:933167104 NOTICE: GL_EXTENSIONS = GL_ARB_imaging GL_ARB_multitexture GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_fence GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_register_combiners GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod GL_SUN_slice_accum
23:17:19 T:3025696624 M:933167104 ERROR: GLX: Same window as before, refreshing context
23:17:19 T:3025696624 M:933167104 WARNING: CreateFile, successfuly opened </usr/share/xbmc/media/splash.png> instead of </usr/share/xbmc/media/Splash.png>
23:17:20 T:3025696624 M:928563200 ERROR: HAL: Failed to initialize hal context: (null)
23:17:20 T:3025696624 M:928563200 ERROR: HAL: no Hal context
23:17:20 T:3025696624 M:928563200 NOTICE: start dvd mediatype detection
23:17:20 T:3025696624 M:928563200 NOTICE: initializing playlistplayer
23:17:20 T:3025696624 M:928563200 NOTICE: DONE initializing playlistplayer
23:17:20 T:3025696624 M:928563200 NOTICE: load default skin:[Confluence]
23:17:20 T:3025696624 M:925671424 NOTICE: initialize done
23:17:20 T:3025696624 M:925671424 NOTICE: Running the application...
23:17:20 T:3025696624 M:925028352 NOTICE: ES: Starting event server
23:17:20 T:3025696624 M:925028352 NOTICE: DS: Starting dbus server
23:17:20 T:2953857904 M:924622848 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
23:17:20 T:2953857904 M:924622848 NOTICE: UDP: Listening on port 9777
23:17:20 T:2937072496 M:923987968 NOTICE: -->Python Interpreter Initialized<--
23:17:20 T:3025696624 M:924241920 ERROR: DS: Failed to connect to the D-Bus session daemon: /usr/bin/dbus-launch terminated abnormally without any error message
23:17:27 T:3025696624 M:915865600 ERROR: GetDirectory - Error getting /root/mnt/hdc6/incoming/files/avi/
23:17:27 T:3025696624 M:915865600 ERROR: CGUIMediaWindow::GetDirectory(/root/mnt/hdc6/incoming/files/avi/) failed
23:17:34 T:3025696624 M:915517440 ERROR: GetDirectory - Error getting /root/mnt/hdc6/incoming/files/avi/
23:17:34 T:3025696624 M:915517440 ERROR: CGUIMediaWindow::GetDirectory(/root/mnt/hdc6/incoming/files/avi/) failed
23:19:13 T:2792639344 M:914698240 NOTICE: -->Python Interpreter Initialized<--
23:19:13 T:2792639344 M:914698240 NOTICE: [PLUGIN] 'SVN Repo Installer: Version - 1.8.1-r1268' initialized!
23:19:13 T:2792639344 M:914698240 NOTICE: ** Required XBMC Revision: r19001 **
23:19:13 T:2792639344 M:914698240 NOTICE: ** Found XBMC Revision: r0 [Unknown] **
23:19:17 T:2745162608 M:914653184 NOTICE: -->Python Interpreter Initialized<--
23:19:17 T:2745162608 M:914518016 NOTICE: [PLUGIN] 'SVN Repo Installer: Version - 1.8.2a-r1335' initialized!
23:19:17 T:2745162608 M:914518016 NOTICE: ** Required XBMC Revision: r19001 **
23:19:17 T:2745162608 M:914518016 NOTICE: ** Found XBMC Revision: r0 [Unknown] **
23:19:20 T:2745162608 M:914690048 NOTICE: -->Python Interpreter Initialized<--
23:19:37 T:2745162608 M:914870272 NOTICE: -->Python Interpreter Initialized<--
23:19:37 T:2745162608 M:914735104 NOTICE: {'XBMC_Revision': 19001,
'author': 'nuka1195/BigBellyBilly',
'category': 'plugins/programs/SVN Repo Installer',
'date': '',
'filepath': '/root/.xbmc/plugins/programs/SVN Repo Installer',
'install': '',
'ioffset': '2',
'readme': '',
'repo': 'xbmc-xbox-skins',
'svn_revision': 1335,
'svn_url': 'http://xbmc-xbox-skins.googlecode.com/svn/trunk/plugins/programs/SVN Repo Installer',
'svn_ver': '1.7.7',
'thumb': '/root/.xbmc/plugins/programs/SVN Repo Installer/default.tbn',
'title': 'SVN Repo Installer',
'version': '1.8.2a',
'voffset': '0'}
23:19:46 T:3025696624 M:914632704 ERROR: GetDirectory - Error getting ?
23:19:46 T:3025696624 M:914632704 ERROR: CGUIMediaWindow::GetDirectory(?) failed
23:19:49 T:2745162608 M:913018880 ERROR: ClearBlock: Trying to clear non existent block /root/.xbmc/plugins/programs/SVN Repo Installer
23:19:50 T:2745162608 M:914587648 NOTICE: -->Python Interpreter Initialized<--
23:19:50 T:2745162608 M:914452480 NOTICE: [PLUGIN] 'SVN Repo Installer: Version - 1.8.2a-r1335' initialized!
23:19:50 T:2745162608 M:914452480 NOTICE: ** Required XBMC Revision: r19001 **
23:19:50 T:2745162608 M:914452480 NOTICE: ** Found XBMC Revision: r0 [Unknown] **
23:19:54 T:2745162608 M:914784256 NOTICE: -->Python Interpreter Initialized<--
23:19:57 T:2745162608 M:914841600 NOTICE: -->Python Interpreter Initialized<--
23:20:00 T:2745162608 M:914845696 NOTICE: -->Python Interpreter Initialized<--
23:24:27 T:2792639344 M:914665472 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
23:24:28 T:2792639344 M:914657280 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
23:24:28 T:2792639344 M:914657280 ERROR: CreateThumbnail: Unable to create thumbfile special://masterprofile/Thumbnails/Video/6/6f25da63.tbn from image http://xbmc-addons.googlecode.com/svn/tr...efault.tbn
23:24:30 T:2736769904 M:914411520 NOTICE: -->Python Interpreter Initialized<--
23:24:30 T:2736769904 M:914149376 NOTICE: {'XBMC_Revision': 19457,
'author': 'The BIT Jockey',
'category': 'plugins/video/Tube8',
'date': '',
'download_url': "download_url='%2Ftrunk%2Fplugins%2Fvideo/Tube8%2F'&repo='xbmc-addons'&install=''&ioffset=2&voffset=0",
'filepath': '/root/.xbmc/plugins/video/Tube8',
'install': '',
'ioffset': '2',
'readme': '',
'repo': 'xbmc-addons',
'svn_revision': 0,
'svn_url': 'http://xbmc-addons.googlecode.com/svn/trunk/plugins/video/Tube8',
'svn_ver': '1.4.3',
'thumb': 'http://xbmc-addons.googlecode.com/svn/trunk/plugins/video/Tube8/default.tbn',
'title': 'Tube 8',
'version': '',
'voffset': '0'}
23:24:37 T:3025696624 M:913436672 ERROR: GetDirectory - Error getting ?
23:24:37 T:3025696624 M:913436672 ERROR: CGUIMediaWindow::GetDirectory(?) failed
23:24:40 T:2736769904 M:912744448 ERROR: ClearBlock: Trying to clear non existent block /root/.xbmc/plugins/programs/SVN Repo Installer
23:24:40 T:2728377200 M:913625088 NOTICE: -->Python Interpreter Initialized<--
1. Enable debug logging.
2. Use pastebin.ca or similar.
Fatal Python error: ceval: tstate mix-up
/usr/bin/xbmc: line 88: 2262 Aborted (core dumped) /usr/share/xbmc/xbmc.bin "$@"
Crash report available at /root/xbmc_crashlog-20100611_055124.log
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Jun 11 05:51:24 CST 2010
XBMC Options:
Arch: i686
Kernel: Linux 2.6.34-rc6-git6 #4 SMP Thu Jun 10 20:50:49 CST 2010
Release: lsb_release not available
############## END SYSTEM INFO ##############
############### STACK TRACE #################
05:50:16 T:3025405808 M:949207040 NOTICE: --------------------------------------------------------------------
05:50:16 T:3025405808 M:949207040 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Jun 10 2010 (SVN:expor
ted)
05:50:16 T:3025405808 M:949207040 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
05:50:16 T:3025405808 M:949207040 NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
05:50:16 T:3025405808 M:949207040 NOTICE: special://home/ is mapped to: /root/.xbmc
05:50:16 T:3025405808 M:949207040 NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
05:50:16 T:3025405808 M:949207040 NOTICE: The executable running is: /usr/share/xbmc/xbmc.bin
05:50:16 T:3025405808 M:949207040 NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
05:50:16 T:3025405808 M:949207040 NOTICE: Setup SDL
05:50:16 T:3025405808 M:948338688 NOTICE: load settings...
05:50:16 T:3025405808 M:948338688 NOTICE: special://profile/ is mapped to: special://masterprofile/
05:50:16 T:3025405808 M:948338688 NOTICE: loading special://masterprofile/guisettings.xml
05:50:16 T:3025405808 M:948338688 NOTICE: Getting hardware information now...
05:50:16 T:3025405808 M:948338688 NOTICE: Checking resolution 12
05:50:16 T:3025405808 M:948338688 NOTICE: Loading player core factory settings from special://xbmc/system/play
ercorefactory.xml.
05:50:16 T:3025405808 M:948338688 NOTICE: Loaded playercorefactory configuration
05:50:16 T:3025405808 M:948338688 NOTICE: Loading player core factory settings from special://masterprofile/pl
05:50:16 T:3025405808 M:948338688 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skippi
ng.
05:50:16 T:3025405808 M:948338688 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedset
tings.xml)
05:50:16 T:3025405808 M:948338688 NOTICE: Default DVD Player: dvdplayer
05:50:16 T:3025405808 M:948338688 NOTICE: Default Video Player: dvdplayer
05:50:16 T:3025405808 M:948338688 NOTICE: Default Audio Player: paplayer
05:50:16 T:3025405808 M:948338688 NOTICE: special://masterprofile/sources.xml
05:50:16 T:3025405808 M:945778688 NOTICE: Using fbConfig[0]
05:50:16 T:3025405808 M:944508928 NOTICE: GL_VENDOR = NVIDIA Corporation
05:50:16 T:3025405808 M:944508928 NOTICE: GL_RENDERER = GeForce2 MX/AGP/SSE2
05:50:16 T:3025405808 M:944508928 NOTICE: GL_VERSION = 1.5.8 NVIDIA 96.43.17
05:50:16 T:3025405808 M:944508928 NOTICE: GL_EXTENSIONS = GL_ARB_imaging GL_ARB_multitexture GL_ARB_pixel_buff
05:50:16 T:3025405808 M:944508928 ERROR: GLX: Same window as before, refreshing context
05:50:16 T:3025405808 M:944508928 WARNING: CreateFile, successfuly opened </usr/share/xbmc/media/splash.png> in
05:50:16 T:3025405808 M:940064768 ERROR: HAL: Failed to initialize hal context: (null)
05:50:16 T:3025405808 M:940064768 ERROR: HAL: no Hal context
05:50:16 T:3025405808 M:940064768 NOTICE: start dvd mediatype detection
05:50:16 T:3025405808 M:940064768 NOTICE: initializing playlistplayer
05:50:16 T:3025405808 M:940064768 NOTICE: DONE initializing playlistplayer
05:50:16 T:3025405808 M:940064768 NOTICE: load default skin:[Confluence]
05:50:17 T:3025405808 M:937201664 NOTICE: initialize done
05:50:17 T:3025405808 M:937201664 NOTICE: Running the application...
05:50:17 T:3025405808 M:936693760 NOTICE: ES: Starting event server
05:50:17 T:3025405808 M:936558592 NOTICE: DS: Starting dbus server
05:50:17 T:2957388656 M:936161280 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
05:50:17 T:2957388656 M:936161280 NOTICE: UDP: Listening on port 9777
05:50:17 T:2940603248 M:935526400 NOTICE: -->Python Interpreter Initialized<--
05:50:17 T:3025405808 M:935780352 ERROR: DS: Failed to connect to the D-Bus session daemon: /usr/bin/dbus-la
05:50:27 T:3025405808 M:924954624 WARNING: Failed to find previously selected audio sink
05:50:32 T:3025405808 M:929394688 NOTICE: Enabled debug logging due to GUI setting. Level 2.
05:50:37 T:3025405808 M:929406976 DEBUG: SDLKeyboard: scancode: 9, sym: 27, unicode: 27, modifier: 0
05:50:37 T:3025405808 M:929406976 DEBUG: OnKey: 61467 pressed, action is 10
05:50:37 T:3025405808 M:929406976 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
05:50:37 T:3025405808 M:929406976 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
05:50:37 T:3025405808 M:929406976 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
05:50:37 T:3025405808 M:929406976 DEBUG: ------ Window Init (Settings.xml) ------
05:50:37 T:3025405808 M:929406976 INFO: Loading skin file: Settings.xml
05:50:37 T:3025405808 M:929406976 DEBUG: Load Settings.xml: 11.16ms
05:50:37 T:3025405808 M:929406976 DEBUG: Alloc resources: 11.84ms (11.64 ms skin load)
05:50:38 T:2812955504 M:925724672 DEBUG: DoWork - took 547 ms to load special://skin/backgrounds/system.jpg
05:50:38 T:3025405808 M:922931200 DEBUG: SDLKeyboard: scancode: 9, sym: 27, unicode: 27, modifier: 0
05:50:38 T:3025405808 M:922931200 DEBUG: OnKey: 61467 pressed, action is 10
05:50:38 T:3025405808 M:922931200 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
05:50:38 T:3025405808 M:922931200 DEBUG: ------ Window Deinit (Settings.xml) ------
05:50:39 T:3025405808 M:922931200 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
05:50:39 T:3025405808 M:922931200 DEBUG: ------ Window Init (Home.xml) ------
05:50:39 T:3025405808 M:922931200 INFO: Loading skin file: Home.xml
05:50:39 T:3025405808 M:922931200 DEBUG: Load Home.xml: 40.37ms
05:50:39 T:3025405808 M:922931200 DEBUG: Alloc resources: 44.71ms (41.91 ms skin load)
05:50:39 T:3025405808 M:921280512 DEBUG: ExecuteXBMCAction : Translating SetFocus(9000)
05:50:39 T:3025405808 M:921280512 DEBUG: ExecuteXBMCAction : To SetFocus(9000)
05:50:40 T:3025405808 M:923439104 DEBUG: SDLKeyboard: scancode: 98, sym: 273, unicode: 0, modifier: 0
05:50:40 T:3025405808 M:923439104 DEBUG: OnKey: 61478 pressed, action is 3
05:50:40 T:3025405808 M:920264704 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
05:50:40 T:3025405808 M:920301568 DEBUG: OnKey: 61453 pressed, action is 7
05:50:40 T:3025405808 M:920301568 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(Programs)
05:50:40 T:3025405808 M:920301568 DEBUG: ExecuteXBMCAction : To ActivateWindow(Programs)
05:50:40 T:3025405808 M:920301568 DEBUG: Activating window ID: 10001
05:50:40 T:3025405808 M:920301568 DEBUG: Checking if window ID 10001 is locked.
05:50:40 T:3025405808 M:920301568 DEBUG: ------ Window Deinit (Home.xml) ------
05:50:40 T:2804562800 M:919666688 DEBUG: DoWork - took 603 ms to load special://skin/backgrounds/programs.jpg
05:50:40 T:3025405808 M:916873216 INFO: Attempting to default to:
05:50:40 T:3025405808 M:916873216 DEBUG: ------ Window Init (MyPrograms.xml) ------
05:50:40 T:3025405808 M:916873216 INFO: Loading skin file: MyPrograms.xml
05:50:40 T:3025405808 M:917000192 DEBUG: Load MyPrograms.xml: 33.25ms
05:50:40 T:3025405808 M:917000192 DEBUG: Alloc resources: 39.51ms (34.25 ms skin load)
05:50:40 T:3025405808 M:917000192 DEBUG: CGUIMediaWindow::GetDirectory ()
05:50:40 T:3025405808 M:917000192 DEBUG: ParentPath = []
05:50:40 T:2766785392 M:917000192 DEBUG: thread start, auto delete: 0
05:50:40 T:2766785392 M:917000192 DEBUG: Thread 2766785392 terminating
05:50:41 T:3025405808 M:924114944 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
05:50:41 T:3025405808 M:924114944 DEBUG: OnKey: 61453 pressed, action is 7
05:50:41 T:3025405808 M:924114944 DEBUG: CGUIMediaWindow::GetDirectory (plugin://programs/)
05:50:41 T:3025405808 M:924114944 DEBUG: ParentPath = []
05:50:41 T:2766785392 M:924114944 DEBUG: thread start, auto delete: 0
--More--
05:50:41 T:2766785392 M:924114944 DEBUG: Thread 2766785392 terminating
05:50:42 T:3025405808 M:924749824 DEBUG: SDLKeyboard: scancode: 104, sym: 274, unicode: 0, modifier: 0
05:50:42 T:3025405808 M:924749824 DEBUG: OnKey: 61480 pressed, action is 4
05:50:42 T:2940603248 M:924495872 DEBUG: DoWork - took 19 ms to load special://masterprofile/Thumbnails/Progr
ams/d153a5ed.tbn
05:50:42 T:3025405808 M:924495872 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
05:50:42 T:3025405808 M:924495872 DEBUG: OnKey: 61453 pressed, action is 7
05:50:42 T:3025405808 M:924495872 DEBUG: CGUIMediaWindow::GetDirectory (plugin://programs/SVN/)
05:50:42 T:3025405808 M:924495872 DEBUG: ParentPath = [plugin://programs/]
05:50:42 T:3025405808 M:924495872 DEBUG: StartScript - URL for plugin settings: SVN/
05:50:42 T:3025405808 M:924495872 DEBUG: unable to load special://home/plugins/programs/SVN/resources/languag
e/Chinese (Simple)/strings.xml: Failed to open file at line 0
05:50:42 T:3025405808 M:924495872 DEBUG: StartScript - calling plugin special://home/plugins/programs/SVN/def
ault.py('plugin://programs/SVN/','0','')
05:50:42 T:3025405808 M:924495872 INFO: initializing python engine.
05:50:42 T:3025405808 M:924495872 DEBUG: Loading: /usr/share/xbmc/system/python/python24-i486-linux.so
05:50:42 T:3025405808 M:924495872 DEBUG: Python wrapper library linked with system Python library
05:50:42 T:3025405808 M:924495872 DEBUG: new python thread created. id=2
05:50:42 T:3025405808 M:924495872 DEBUG: WaitOnScriptResult - waiting on the SVN plugin...
05:50:42 T:2758392688 M:924495872 DEBUG: thread start, auto delete: 0
05:50:42 T:2758392688 M:924495872 DEBUG: Python thread: start processing
05:50:42 T:2758392688 M:924495872 NOTICE: -->Python Interpreter Initialized<--
05:50:42 T:2758392688 M:924495872 DEBUG: Process - The source file to load is special://home/plugins/programs
/SVN/default.py
05:50:42 T:2758392688 M:924495872 DEBUG: Process - Setting the Python path to /root/.xbmc/plugins/programs/SV
N:/usr/lib/python24.zip:/usr/lib/python2.4/:/usr/lib/python2.4/plat-linux2:/usr/lib/python2.4/lib-tk:/usr/lib/p
ython2.4/lib-dynload
05:50:42 T:2758392688 M:924495872 DEBUG: Process - Entering source directory /root/.xbmc/plugins/programs/SVN
05:50:42 T:2758392688 M:924495872 NOTICE: [PLUGIN] 'SVN Repo Installer: Version - 1.8.1-r1268' initialized!
05:50:42 T:2758392688 M:924495872 NOTICE: ** Required XBMC Revision: r19001 **
05:50:42 T:2758392688 M:924495872 NOTICE: ** Found XBMC Revision: r0 [Unknown] **
05:50:42 T:2758392688 M:924360704 DEBUG: [SVN Repo Installer]: Module: installerAPI.xbmcplugin_lib Dated: 24-
06-2009 loaded!
05:50:42 T:2758392688 M:924360704 DEBUG: [SVN Repo Installer]: Module: installerAPI.xbmcplugin_list Dated: 24
-06-2009 loaded!
05:50:42 T:2758392688 M:924360704 DEBUG: [SVN Repo Installer]: installerAPI.xbmcplugin_list.Main init!
05:50:42 T:2758392688 M:924360704 DEBUG: [SVN Repo Installer]: Info() dict={'title': ''}
05:50:42 T:2758392688 M:924360704 DEBUG: [SVN Repo Installer]: load_repos() ['xbmc-xbox-skins', 'queeup-xbmc'
, 'dandar3-xbmc-addons', 'xbmc-addons', 'xbmc-scripting']
05:50:42 T:3025405808 M:924360704 DEBUG: WaitOnScriptResult- plugin returned successfully
05:50:42 T:2758392688 M:924360704 INFO: Scriptresult: Success
05:50:42 T:2749999984 M:924360704 DEBUG: thread start, auto delete: 0
05:50:42 T:2749999984 M:924360704 DEBUG: Thread 2749999984 terminating
05:50:42 T:2766785392 M:924360704 DEBUG: thread start, auto delete: 0
05:50:42 T:2766785392 M:924360704 DEBUG: Thread 2766785392 terminating
05:50:43 T:3025405808 M:928296960 DEBUG: SDLKeyboard: scancode: 104, sym: 274, unicode: 0, modifier: 0
05:50:43 T:3025405808 M:928296960 DEBUG: OnKey: 61480 pressed, action is 4
05:50:43 T:2787773296 M:928296960 DEBUG: DoWork - took 7 ms to load /root/.xbmc/plugins/programs/SVN/resource
s/media/update_checker.png
05:50:43 T:2758392688 M:928296960 INFO: Python script stopped
05:50:43 T:2758392688 M:928296960 DEBUG: Thread 2758392688 terminating
05:50:43 T:3025405808 M:928296960 DEBUG: python thread 2 destructed
05:50:43 T:3025405808 M:928296960 INFO: Python, unloading python24.dll because no scripts are running anymor
e
05:50:43 T:3025405808 M:928296960 DEBUG: UnloadExtensionLibs, clearing python extension libraries
05:50:43 T:3025405808 M:928296960 DEBUG: Unloading: python24-i486-linux.so
05:50:43 T:2812955504 M:928309248 DEBUG: DoWork - took 7 ms to load /root/.xbmc/plugins/programs/SVN/resource
s/media/svn_repo.png
05:50:43 T:3025405808 M:928309248 DEBUG: SDLKeyboard: scancode: 104, sym: 274, unicode: 0, modifier: 0
05:50:43 T:3025405808 M:928309248 DEBUG: OnKey: 61480 pressed, action is 4
05:50:44 T:3025405808 M:928309248 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
05:50:44 T:3025405808 M:928309248 DEBUG: OnKey: 61453 pressed, action is 7
05:50:44 T:3025405808 M:928309248 DEBUG: CGUIMediaWindow::GetDirectory (plugin://programs/SVN/?category='root
'&repo='xbmc-addons'&title='xbmc-addons')
05:50:44 T:3025405808 M:928309248 DEBUG: ParentPath = [plugin://programs/SVN/]
05:50:44 T:3025405808 M:928309248 DEBUG: StartScript - URL for plugin settings: SVN/
05:50:44 T:3025405808 M:928309248 DEBUG: unable to load special://home/plugins/programs/SVN/resources/languag
05:50:44 T:3025405808 M:928309248 DEBUG: StartScript - calling plugin special://home/plugins/programs/SVN/def
ault.py('plugin://programs/SVN/','0','?category='root'&repo='xbmc-addons'&title='xbmc-addons'')
05:50:44 T:3025405808 M:928309248 INFO: initializing python engine.
05:50:44 T:3025405808 M:928309248 DEBUG: Loading: /usr/share/xbmc/system/python/python24-i486-linux.so
05:50:44 T:3025405808 M:928309248 DEBUG: Python wrapper library linked with system Python library
05:50:44 T:3025405808 M:928309248 DEBUG: new python thread created. id=3
05:50:44 T:3025405808 M:928309248 DEBUG: WaitOnScriptResult - waiting on the SVN plugin...
05:50:44 T:2758392688 M:928309248 DEBUG: thread start, auto delete: 0
05:50:44 T:2758392688 M:928309248 DEBUG: Python thread: start processing
--More--
05:50:44 T:2758392688 M:928309248 NOTICE: -->Python Interpreter Initialized<--
05:50:44 T:2758392688 M:928309248 DEBUG: Process - The source file to load is special://home/plugins/programs
/SVN/default.py
05:50:44 T:2758392688 M:928174080 DEBUG: Process - Setting the Python path to /root/.xbmc/plugins/programs/SV
05:50:44 T:2758392688 M:928174080 DEBUG: Process - Entering source directory /root/.xbmc/plugins/programs/SVN
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: Module: installerAPI.xbmcplugin_lib Dated: 24-
06-2009 loaded!
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: Module: installerAPI.xbmcplugin_list Dated: 24
-06-2009 loaded!
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: installerAPI.xbmcplugin_list.Main init!
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: Info() dict={'repo': 'xbmc-addons', 'category'
: 'root', 'title': 'xbmc-addons'}
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: get_repo_info() REPO_URL=http://xbmc-addons.go
oglecode.com/svn REPO_ROOT=/trunk REPO_STRUCTURES=[('plugins', '-2', '', '2', '0'), ('scripts', '-1', '', '2',
'0'), ('skin', '-1', '', '2', '0')]
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: get_xbmc_revision() 0
05:50:44 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: readURL() url=http://xbmc-addons.googlecode.co
m/svn/trunk
05:50:45 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: installerAPI.xbmcplugin_list.Parser __init__!
05:50:45 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: _fill_list()
05:50:45 T:2758392688 M:928178176 DEBUG: [SVN Repo Installer]: saveFileObj() /root/.xbmc/plugins/programs/SVN
/installed_items.dat
05:50:45 T:3025405808 M:928178176 DEBUG: WaitOnScriptResult- plugin returned successfully
05:50:45 T:3025405808 M:928178176 DEBUG: Saving fileitems [plugin://programs/SVN/?category='root'&repo='xbmc-
addons'&title='xbmc-addons']
05:50:45 T:2758392688 M:928178176 INFO: Scriptresult: Success
05:50:45 T:3025405808 M:928178176 DEBUG: -- items: 4, sort method: 0, ascending: false
05:50:45 T:2749999984 M:928178176 DEBUG: thread start, auto delete: 0
05:50:45 T:2749999984 M:928178176 DEBUG: Thread 2749999984 terminating
05:50:46 T:2758392688 M:927670272 INFO: Python script stopped
05:50:46 T:2758392688 M:927670272 DEBUG: Thread 2758392688 terminating
05:50:46 T:3025405808 M:927670272 DEBUG: python thread 3 destructed
05:50:46 T:3025405808 M:927670272 INFO: Python, unloading python24.dll because no scripts are running anymor
e
05:50:46 T:3025405808 M:927670272 DEBUG: UnloadExtensionLibs, clearing python extension libraries
05:50:46 T:3025405808 M:927670272 DEBUG: Unloading: python24-i486-linux.so
05:50:46 T:3025405808 M:927764480 DEBUG: SDLKeyboard: scancode: 104, sym: 274, unicode: 0, modifier: 0
05:50:46 T:3025405808 M:927764480 DEBUG: OnKey: 61480 pressed, action is 4
05:50:46 T:3025405808 M:927764480 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
05:50:46 T:3025405808 M:927764480 DEBUG: OnKey: 61453 pressed, action is 7
05:50:46 T:3025405808 M:927764480 DEBUG: CGUIMediaWindow::GetDirectory (plugin://programs/SVN/?category="%2Ft
runk/plugins%2F"&repo='xbmc-addons'&install=""&ioffset=2&voffset=0&title='xbmc-addons')
05:50:46 T:3025405808 M:927764480 DEBUG: ParentPath = [plugin://programs/SVN/?category='root'&repo='xbmc-ad
05:50:46 T:3025405808 M:927764480 DEBUG: StartScript - URL for plugin settings: SVN/
05:50:46 T:3025405808 M:927764480 DEBUG: unable to load special://home/plugins/programs/SVN/resources/languag
05:50:46 T:3025405808 M:927764480 DEBUG: StartScript - calling plugin special://home/plugins/programs/SVN/def
ault.py('plugin://programs/SVN/','0','?category="%2Ftrunk/plugins%2F"&repo='xbmc-addons'&install=""&ioffset=2&v
offset=0&title='xbmc-addons'')
05:50:46 T:3025405808 M:927764480 INFO: initializing python engine.
05:50:46 T:3025405808 M:927764480 DEBUG: Loading: /usr/share/xbmc/system/python/python24-i486-linux.so
--More--
05:50:46 T:3025405808 M:927764480 DEBUG: Python wrapper library linked with system Python library
05:50:46 T:3025405808 M:927764480 DEBUG: new python thread created. id=4
05:50:46 T:3025405808 M:927764480 DEBUG: WaitOnScriptResult - waiting on the SVN plugin...
05:50:46 T:2758392688 M:927764480 DEBUG: thread start, auto delete: 0
05:50:46 T:2758392688 M:927764480 DEBUG: Python thread: start processing
05:50:46 T:2758392688 M:927764480 NOTICE: -->Python Interpreter Initialized<--
05:50:46 T:2758392688 M:927764480 DEBUG: Process - The source file to load is special://home/plugins/programs
/SVN/default.py
05:50:46 T:2758392688 M:927764480 DEBUG: Process - Setting the Python path to /root/.xbmc/plugins/programs/SV
05:50:46 T:2758392688 M:927764480 DEBUG: Process - Entering source directory /root/.xbmc/plugins/programs/SVN
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: Module: installerAPI.xbmcplugin_lib Dated: 24-
06-2009 loaded!
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: Module: installerAPI.xbmcplugin_list Dated: 24
-06-2009 loaded!
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: installerAPI.xbmcplugin_list.Main init!
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: Info() dict={'voffset': 0, 'category': '/trunk
/plugins/', 'install': '', 'title': 'xbmc-addons', 'repo': 'xbmc-addons', 'ioffset': 2}
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: get_repo_info() REPO_URL=http://xbmc-addons.go
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: get_xbmc_revision() 0
05:50:46 T:2758392688 M:927629312 DEBUG: [SVN Repo Installer]: readURL() url=http://xbmc-addons.googlecode.co
05:50:47 T:2758392688 M:927633408 DEBUG: [SVN Repo Installer]: installerAPI.xbmcplugin_list.Parser __init__!
05:50:47 T:2758392688 M:927633408 DEBUG: [SVN Repo Installer]: _fill_list()
Pages: 1 2
