siksy Wrote:It's essential tv-show's subtitle resource for southeast europe.
no its not, podnapisi, opensubtitles and titlovi have more than enough.... and I speak from experience
Well, my experience is quite opposite because prijevodi-online.org is specialized for tv shows titles, and only for tv shows titles. No other srb/cro/bos website has such tv shows subtitles base as this one.
Anyway,It was only a suggestion...
siksy Wrote:Well, my experience is quite opposite because prijevodi-online.org is specialized for tv shows titles, and only for tv shows titles. No other srb/cro/bos website has such tv shows subtitles base as this one.
Without the approval from the websites administrator I would not even consider writing the service for it
john.doe Wrote:Sta se desava sa addonom?Titlove sa podnapisi.com nemoze raspakirati?
I zasto se ne ubaci jos neki poput http://www.prijevodi-online.org?:sniffle:
Za podnapisi.net moras da se registrujes
A za projevodi-online, uzmi pa napisi service i ja cu ga ubaciti
Hi Amet!
Great job with this plugin.
Anyway you can include "http://subtitrari.regielive.ro/" this is for Romanian subtitles only.
Thank you for your great work
I'm using a recent pre-Eden build, in combination with the Bierdopje service (Dutch subtitles for series).
The past two weeks I get the error 'Failed to get ID from bierdopje', for series I know for sure that do have an ID at Bierdopje.
Is this a known problem? I read about the solution of adding ID by hand, but this seems to be a systematic problem not a one-off.
bartmans Wrote:Hi,
hard to say without a debug log
This addon worked like a charm... but suddenly it stopped working. I haven't changed a thing (unless some auto update screwed me). I can search for subtitles and it says "downloading" but afterwards it tells me "error extracting subtitles". Is there a solution I missed or?
Where can I find the debug log, or how do I create one?
So this is a new problem that hasn't occured to anyone else? Going to try to create a debug log... even though my first attempt failed
Bogga Wrote:So this is a new problem that hasn't occured to anyone else? Going to try to create a debug log... even though my first attempt failed
well, not sure what to say... we have about 20 services, and I personally only use 2. you haven't said what service doesn't work for you so I cant test to tell you if it works for me. regardless, to fix it, we do need that log
