mrgoolie Wrote:My excuses for the wrong log file.
Here is the correct one : http://pastebin.com/nGvw0Tpa
seems that xbmc didnt like "/storage/tvshows/Dexter/Season 06/Dexter - 6x04 - A Horse of a Different Color.nl.srt" does that file exist?
what about using other services? OpenSubtitles?
amet Wrote:seems that xbmc didnt like "/storage/tvshows/Dexter/Season 06/Dexter - 6x04 - A Horse of a Different Color.nl.srt" does that file exist?
Nope that file doesn't exist...
In fact I see that normally when you download a file, first it downloads the file to a temp folder (\\192.168.1.133\xbmc\userdata\addon_data\script.xbmc.subtitles\sub_tmp) and then it copies it to the destination folder.
So in fact it even does'nt download it...
It doesn't work with other services as well, like ondertitel.
mrgoolie Wrote:Nope that file doesn't exist...
and we know that "\\192.168.1.133\xbmc\userdata\addon_data\script.x bmc.subtitles\sub_tmp" is writable?
can that be changed to local folder just to verify?
amet Wrote:and we know that "\\192.168.1.133\xbmc\userdata\addon_data\script.x bmc.subtitles\sub_tmp" is writable?
Strange, if I right click the folder sub_temp I see read only, if I uncheck this and click ok and i right click again I see read only again
Other folders are read only as well.
How can I change this folder?
amet Wrote:Absolutely no idea ...
I hope somebody else can help me here
Is it normal that this folder is read only?
mrgoolie Wrote:I hope somebody else can help me here
No, but it's also not normal that you have it on network
amet Wrote:No, but it's also not normal that you have it on network
It's not on my network
192.168.1.133 is the ip of my xbmc
So in fact those folders are local.
amet Wrote:ok, if you say so.... still nothing I can do about it
so somebody else... Help me!
mrgoolie Wrote:so somebody else... Help me!
hi,
can you boot a linux live system like ubuntu live or so and run a filesystem check on the partitions?
on the unmounted partition run something like
replace Xy with the partition
Hi!
First of:Awesome app you made! It is wonderful.
Now to my problem: After the latest update by your app my subs gets renamed to "temp_sub" for some reason. It worked peerfectly all the way up to 11. eden beta 3. I could do a rollback to the previous version of your app and it worked.
I have now eden rc1 but since i reinstalled i can't rollback to previous version and try it out if it works with the RC1
win7x64@
htpc
Debug Log:
http://pastebin.com/jPYwsvkD
Ideas?
Edit: I could rollback to 2.9.31 on Eden RC1 and it works again so the problem lies in the new .33 version
Please have a look
khold Wrote:Hi!
win7x64@htpc
Debug Log: http://pastebin.com/jPYwsvkD
Ideas?
Please have a look
you have "disable hash search" on in the addon settings? any reason for that?
