amet Wrote:you have "disable hash search" on in the addon settings? any reason for that?
No I think i checked it a long time ago cause of something I read here then but I don't remember what.
Could that be it?
I'll check
Edit: that was not it the problem persists and no I don't see any difference between it on or off so what should it be?
khold Wrote:No I think i checked it a long time ago cause of something I read here then but I don't remember what.
Could that be it?
I'll check
show me the log with it off please
amet Wrote:the only other reason I can see this happening is that you are playing file in file mode instead of Library mode. is that the case?
Yeah I do. Is it necessary from now on to use library mode?
Can I do a manual update? I m running OE...
I think I am running 2.5.16
Update: I updated my OE installation to eden 3 (daily build) and now the subs work
Don't know what the problem before was.
Amet, Thanks for your help!
I cannot install the addon in EDEN rc
Seems file is missing on server.
Or to be exact: 2.9.33 is the one eden tries to download but 2.9.34 exists on the server....
** log removed **
Hi
I'm having trouble with your addon : it just won't download the subtitles, even if it shows a message "file downloaded and extracted"
Here is the log :
http://pastebin.com/eLXDXvsj
jonaz Wrote:I cannot install the addon in EDEN rc Seems file is missing on server.
** log removed **
Please do not c/p logs in the thread, use pastebin.com and post link here. Full log is needed, do not clip it.
MagicMicky Wrote:Hi
Here is the log :
Full log is needed, looks like its having issue with special characters ...
khold Wrote:Yeah I do. Is it necessary from now on to use library mode?
Didn't get an answer to that so I bring a fresh debug using same setup but with the v 2.9.31 Everything works like it should so you have done something in the versions after.
http://pastebin.com/0PMuVaTH
Can you please look into it as i need to use file view for my incoming folder since it contains more then tv series.
I use Videos - Files - Folder
Thanks in advance
khold Wrote:Didn't get an answer to that so I bring a fresh debug using same setup but with the v 2.9.31 Everything works like it should so you have done something in the versions after.
Thanks in advance
try this
https://github.com/amet/script.xbmc.subt...46261a341b
that should work but I am not sure if it will introduce any issues
