You're welcome. Thanks for developing this nice script
If I may suggest, it could be nice to be able to download subtitles for an entire folder (1 season per example) in a row
amet Wrote:with zip or with manual changes?
Manual changes.
I've got an idea of feature for this add-on, let me know what you think of it :
Having an option to download a subtitle, load it, and then, delete it (something like setting the download path to userdata\addon_data\script.xbmc.subtitles\sub_tmp). What do you think ?
Shadok Wrote:You're welcome. Thanks for developing this nice script
nice try, been over that
we need the file to be open to know the hash for sync value for some scripts and noone guarantees that the file will match...
jackripper Wrote:Manual changes.
I wonder why? set the addon setting to "not use hash" and the file will be saved in tmp folder and deleted on next run
Hi Amet,
I have a problem with downloading subs from podnapisi.net - it just hangs on downloading subtitles ( I checked my user name and password, it's OK). OpenSubtitles work but titlovi.com also doesen't work.
Here is my log:
http://pastebin.com/sJxpLWX2
Pozdrav i hvala unaprijed!
amet Wrote:I wonder why? set the addon setting to "not use hash" and the file will be saved in tmp folder and deleted on next run
I've tried that. The subtitle file is downloaded in the movie folder, with a temporary name "temp_sub.en.srt", but never deleted after that.
http://pastebin.com/P67Q5eeM
Hi amet.
I've been experiencing some problems with this amazing add-on too.
I'm Portuguese so I mainly use two services, LegendasDivx.com and Legendas.tv.
I think both have different problems so I created a debug log for each.
First, whenever I try to download a subtitle from LegendasDivx.com the gui shows up just fine and the subtitles available are there, but whenever I choose one for download, it just hangs in there and nothing happens.
This is the log for this:
http://pastebin.com/HturR0BU
Now, for legendas.tv, I can download the first subtitle, but if I then try with a different episode or movie, it won't work.
http://pastebin.com/NfKpusRe
As you can see, the first file works fine but the next one doesn't.
Any help would be much appreciated.
Best Regards,
Lysin
Edit: Forgot to mention that the errors are reproducible in both my server and my own laptop.
amet Wrote:nice try, been over that
Ok
It was just a suggestion anyway.
And the download first sync option works fine.
lysin Wrote:Hi amet.
This is the log for this: http://pastebin.com/HturR0BU
Best Regards,
Lysin
Known issues, we are waiting for legendas service author to look into it
anteST Wrote:Hi Amet,
Here is my log: http://pastebin.com/sJxpLWX2
We need a debug log, my signature has how to
jackripper Wrote:I've tried that. The subtitle file is downloaded in the movie folder, with a temporary name "temp_sub.en.srt", but never deleted after that.
Will check more in a next day or so
anteST Wrote:I hope this is the right one: http://pastebin.com/XZ8qaaHj
titlovi fix is
here
no idea whats wrong with podnapisi, has it always been like that or did it start recently?
amet Wrote:titlovi fix is here
I just installed xbmc and xbmc subtitles maybe two weeks ago. Podnapisi worked maybe day or two and after that it just hangs on download. I tried reinstalling xbmc and xbmc subtitles several times but no luck.
