(2012-03-21, 22:56)qofbored Wrote: [ -> ]No change with that..
Debug Log please
Hi, Amet
Do you know when (an estimate) are you going to push an updated version of this plugin to the official repository?
Thanks for the hard work.
(2012-03-22, 17:17)tebicenter Wrote: [ -> ]Hi, Amet
what are you after?
Hi Amet,
First, let me thank you for this addon.
I have a question; how can I enable account login for opensubtitels.org?
Thanks in advance.
(2012-03-22, 23:58)barambulli Wrote: [ -> ]Hi Amet,
Thanks in advance.
There is no way to use login details for opensubtitles. Why would you want to?
[script.xbmc.subtitles] -v 2.9.38
- fix Argenteam service
- "fix" for Subdivx service, not happy with this but best I can do for now
- Select the current service in the service list, thx Martin Wallgren
- fixed Bulgarian addon.xml localization, thx Kiril
(2012-03-23, 07:59)amet Wrote: [ -> ] (2012-03-22, 23:58)barambulli Wrote: [ -> ]Hi Amet,
Thanks in advance.
Because it limits the number of downloads per IP and when you have an ISP with only one IP on the Gateway, you virtually cannot download anything unless you have logged in.
Is there a way to modify the script or include this feature in the next release?
(2012-03-23, 13:10)barambulli Wrote: [ -> ] (2012-03-23, 07:59)amet Wrote: [ -> ] (2012-03-22, 23:58)barambulli Wrote: [ -> ]Hi Amet,
Thanks in advance.
I think that API doesn't allow for user login, will have a look but I wouldn't hold my breath
(2012-03-23, 13:26)amet Wrote: [ -> ] (2012-03-23, 13:10)barambulli Wrote: [ -> ] (2012-03-23, 07:59)amet Wrote: [ -> ]There is no way to use login details for opensubtitles. Why would you want to?
Thanks in any case.
does anybody have problems with opensubtitles.org, it downloads the TXT files, but looks like the files have linux/unix line separators and the subtitles are not displayed correctly on windows machines.
let me know if this arleady has been addressed.
Hi, love your script but it wont unzip files for me:
** c/p log removed **
I checked and it actually downloads proper file, but wont unzip it. \\DS\Files is mounted as Z: drive
I tried installing winzip/winrar/7zip to see if it helps but it didnt, ideas
What is the right way to provide XMBC team with info in order to solve a problem
with the subtitle download problem from "subscenter.org" and "sratim.co.il"?
Thank you.
(2012-03-24, 09:23)komarto Wrote: [ -> ]Hi,
Thank you.
Debug Log and a brief explanation
please note that both services are made by orivar , I hope he reads these threads and can assist you with the issues.
(2012-03-24, 01:01)robwiel Wrote: [ -> ]Hi, love your script but it wont unzip files for me:
let us have the full
Debug Log to pastebin.com
(2012-03-24, 01:01)robwiel Wrote: [ -> ]I checked and it actually downloads proper file, but wont unzip it. \\DS\Files is mounted as Z: drive
installing winzip/winrar or any other external software wont help as XBMC makes no use of them, all is handled internally
