Just to let you know that I'm having the same error, but only happens on legendas.tv, so I think it's probably something that changed over at legendas.tv...
gabrielsturmer Wrote:The file is big, but i think that the part tha matters is this one:
*** removed c/p debug log ***
Hello guys!
I'm trying to get this script running to download dutch subtitles for my series from bierdopje.nl, but every serie I try, I keep on getting this error message:
failed to get a show id for (name episode)
after i click ok it says:
iterable item required.
i checked on bierdopje and my video files are named exactly the same as listed on that site...
what am i missing here or doing wrong?
timmeh604 Wrote:Hello guys!
please post a debug log, my signature has how-to
Xbmc Subtitles on Legendas.tv find the files but wont download then! (or download but not copy to proper location )
2.2.7 is out and it should fix the Legendas.TV issue(or any other service for that matter)
please let me know if it works for you
Cheers,
amet
Undertexter.se Swesub.nu doesnt work for me.
HereĀ“s my log:
http://pastebin.com/1pD9LBWW
Really hope you can work this out since i cant live without that script
Same here. When opening the subtitle search all I get is blank white screen (using alaska skin). When I eventually leave page since nothing happens I get "error: script.failed script.xbmc.subtitles".
Tried to clear cache dir and change the default subtitle source but those didn't solve problem.
debug:
http://pastebin.com/kXEp3Ena
john.doe Wrote:Just to let you know that I'm having the same error, but only happens on legendas.tv, so I think it's probably something that changed over at legendas.tv...
For me, it happens in every single source, not just legendas.tv...
Anyone else?
gabrielsturmer Wrote:For me, it happens in every single source, not just legendas.tv...
Anyone else?
is that with 2.2.7? debug log?
lateko Wrote:Same here. When opening the subtitle search all I get is blank white screen (using alaska skin). When I eventually leave page since nothing happens I get "error: script.failed script.xbmc.subtitles".
debug:
alaska's script-XBMC-Subtitles-main.xml needs an update, since 2.2.6 script doesnt support old window layout
xbmcmark Wrote:having trouble with all subtitle sources:
http://pastebin.com/6m9RdWY9
1. dont clip the log.
2. what version of addon are you running?
3. do any other addons that are using internet work?
looks like you dont have internet connection
amet Wrote:1. dont clip the log.
They do work, since in writing this :p
Anyhow, a .srt file gets created inside the tv folder
And it contains this
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /utext.php was not found on this server.</p>
<hr>
<address>Apache/2.2.3 (CentOS) Server at
http://www.undertexter.se Port 80</address>
</body></html>
And i dont know what you mean by dont clip log
Latest version of the addon.
debug:
didnt think any skins were using old window
can you please try this one -.
https://github.com/downloads/amet/script..._2.2.8.zip and let me know.
anyone else seeing issues on it should try to update, use "install from zip file" option and select script.xbmc.subtitles_2.2.8.zip
thanks and sorry for the trouble
amet
