Thanks for the what looks to be great Plugin!
I just have a few questions to ask first of all:
I'm running Dharma RC2 (I've read elsewhere that it's not worth updating/upgrading, and last time I tried such a thing I broke the entirety of XBMC, so I'd rather not risk it)
and in the "Settings> addons" part of the options, I can see "Music OSD" but there is no sign of a "Video" or "Movie" OSD!
Any suggestions?
Thanks, Kris
When i try to access the subtitles when Iam watching a movie/tv show I just get "script failed" when i click the subtitles icon.
Iam running XBMC in portable mode on a external USB drive.
Log:
http://pastebin.com/9SjXPyXL
Line 149 and forward
Hope you can help and thanks for a otherwise great addon.
I use subdivx, and search correctly but when i click on Download, never finish.
Ubuntu 10.04
Subtitles addon 2.3.0
What can i do?
It's the problem you are working on?
2.3.2 is out on github, if anyone cares to test and report back before I push it to official repo
Quote:2.3.2
- added: support for xbmcvfs module, with this its possible to search by hash and save on smb:// drives.
amet Wrote:2.3.2 id out on github, if anyone cares to test and report back before I push it to official repo
Zeljko, what are the platforms affected and aimed by this fix? ATV2?
gfjardim Wrote:Zeljko, what are the platforms affected and aimed by this fix? ATV2?
Atv2/iOS with the latest git build( or the next official ) and any xbmc using external python.
I'm currently running OpenElec RC1 / XBMC.
For some reason I cannot install XBMC Subtitles using XBMC's addon repository.
...so: I decided to copy/paste the script from a different XBMC install. But to no avail: The script says downloaded but nothing is shown.
...last but not least I tried version 2.3.2 (using install-from-zip).
This however acts the same: the file isn't downloaded and is thus never shown.
(I assume it is a problem with rights on the temporary sub folder...)
FYI: My video files are stored on a NAS and are accessed using a SMB share (with guest read/write access).
amet Wrote:2.3.2 is out on github, if anyone cares to test and report back before I push it to official repo
Corvo Wrote:I'm currently running OpenElec RC1 / XBMC.
It works when you mount it first using cifs.
EDIT
updating to 10.0-7 solved my issue. thx.
Hi Amet and mr_blobby,
Thanks for all the work on this plugin. Just wanted to let you know that with the latest XBMC build on ATV2 ( git d651965) and your latest Subtitle addon (2.3.3), I now can save the subtitle on my SMB share
Thats really great! Thanks!!
Hi! Everyone,
I run into a bit of a problem and hope someone can help me out.
I use XBMC for some month now but just recently discovered the subtitle addon.
It works like a charm if I use Confluence but normally I prefer the Alaska Rev Skin and for some reasons, if I download subs while using Alaska they don't get displayed afterwards. If I switch to confluence download them there and switch back to Alaska everything works fine.
Anyone got a Idea what could be the problem ?
Senonlyone Wrote:Hi! Everyone,
no idea, debug log while trying to do it in Alaska Rev might have some answers
I was thinking about adding support for legendasdivx.com. It's the most popular website for portuguese (Portugal) subtitles.
Are there any guidelines for adding new websites? Maybe the code is self explanatory... I haven't read anything yet.
Thanks for the reply amet.
I think this is what goes wrong:
Quote:14:20:29 T:3004 M:2714034176 DEBUG: SDLKeyboard: scancode: 28, sym: 13, unicode: 13, modifier: 0
14:20:29 T:3004 M:2714034176 DEBUG: CApplication::OnKey: 61453 pressed, action is Select
14:20:29 T:2312 M:2714034176 DEBUG: ### [XBMC Subtitles-gui] - In 'On click' selected : [0]
14:20:29 T:2312 M:2714034176 DEBUG: ### [XBMC Subtitles-gui] - Selected : [0]
14:20:30 T:2312 M:2714271744 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(stack) in stack://I:\Movies\Welcome To The Rileys\Welcome.To.The.Rileys.LiMiTED.BDRip.XviD-DASH.CD1.avi , I:\Movies\Welcome To The Rileys\Welcome.To.The.Rileys.LiMiTED.BDRip.XviD-DASH.CD2.en.srt
14:20:30 T:2144 M:2714025984 WARNING: Previous line repeats 2 times.
14:20:30 T:2144 M:2714025984 NOTICE: Opening Subtitle stream: 0 source: 1024
14:20:30 T:2144 M:2714025984 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(stack) in stack://I:\Movies\Welcome To The Rileys\Welcome.To.The.Rileys.LiMiTED.BDRip.XviD-DASH.CD1.avi , I:\Movies\Welcome To The Rileys\Welcome.To.The.Rileys.LiMiTED.BDRip.XviD-DASH.CD2.en.srt
14:20:30 T:2144 M:2714025984 ERROR: CDVDPlayerSubtitle::OpenStream - Unable to create subtitle parser
14:20:30 T:2144 M:2714025984 WARNING: CDVDPlayer::OpenSubtitleStream - Unsupported stream 0. Stream disabled.
14:20:30 T:3004 M:2714025984 DEBUG: ------ Window Deinit (H:\Documents and Settings\Admin\Application Data\XBMC\addons\skin.alaska.revisited.mod\720p\script-XBMC-Subtitles-main.xml) ------
14:20:30 T:2224 M:2714025984 DEBUG: CDVDPlayerAudio:: Discontinuity - was:147487534.286791, should be:147491898.837244, error:4364.550453
14:20:30 T:3004 M:2714025984 DEBUG: CAnnouncementManager - Announcement: PlaybackResumed from xbmc
14:20:30 T:2312 M:2714025984 INFO: Scriptresult: Success
14:20:30 T:2312 M:2714025984 INFO: Python script stopped
14:20:30 T:2312 M:2714025984 DEBUG: Thread 2312 terminating
14:20:30 T:2224 M:2714066944 DEBUG: CDVDPlayerAudio:: Discontinuity - was:142419293.401275, should be:147556370.200391, error:5137076.799116
14:20:30 T:3004 M:2714066944 DEBUG: python thread 5 destructed
14:20:30 T:3004 M:2714066944 ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block H:\Documents and Settings\Admin\Application Data\XBMC\addons\script.xbmc.subtitles
14:20:31 T:3004 M:2713882624 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
14:20:33 T:1020 M:2716143616 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.40
14:20:38 T:3924 M:2718035968 DEBUG: Thread 3924 terminating (autodelete)
14:20:39 T:3932 M:2718076928 DEBUG: Thread 3932 terminating (autodelete)
14:20:40 T:3004 M:2718887936 DEBUG: SDLKeyboard: scancode: 50, sym: 109, unicode: 109, modifier: 0
14:20:40 T:3004 M:2718887936 DEBUG: CApplication::OnKey: 61517 pressed, action is OSD
Senonlyone Wrote:Thanks for the reply amet.
we dont deal with "stack://" movies well... it has always been the low priority to me.
