Really love this addon works great, but is it maybe possible to support the following website to support Chinese subtitles.
http://www.shooter.cn/
I am not familiar with developing in python otherwise I would look into that myself.
amet Wrote:hehe, I have only found 2 part movies to test with didnt know that 3 part existed...
Any plans to support more than 2 part movies?
bradvido88 Wrote:Any plans to support more than 2 part movies?
Not at the moment , would have to find a movie that's done in 3 parts and that the 3 part sub is available for it. Will look, but no promisses
Is there a way to get XBMC Subtitles to run automatically for every movie?
amet Wrote:if you have enabled it in skin, all you need to do is click on subtitle button on OSD, which I dont know what it looks like in Rapier
I am unsure if your last post relates to me, but I can not see how to use this plugin.
I have added it, then enabled it in addons. I have configured it. but when i am playing a show and select subtiles from the menu, there is nothing there that lets me search. Just the usual. If i push T is says disabled..
any ideas?
UserInterface Wrote:I am unsure if your last post relates to me, but I can not see how to use this plugin.
any ideas?
I can't find the Rapier skin in the
official skins addon repository, so i guess you downloaded it from
here.
When I look at the skin files, I see that it hasn't been updated to support the xbmc subtitltes script.
In fact, it has got the old, outdated "opensubtitles_osd" script hardcoded in the skin
What you need to do, is edit this file: Rapier\720p\VideoOSDSettings.xml
and change this line:
<onclick>RunScript(special://home/scripts/OpenSubtitles_OSD/default.py, [TV]$INFO[VideoPlayer.Season] $INFO[VideoPlayer.Episode] $INFO[VideoPlayer.TVshowtitle][/TV])</onclick>
to:
<onclick>XBMC.RunScript(script.xbmc.subtitles)</onclick>
<onclick>RunScript(special://home/scripts/OpenSubtitles_OSD/default.py, [MOVIE]$INFO[VideoPlayer.Title][/MOVIE])</onclick>
to:
After these changes, the script can be run by pressing a button:
I don't have any of those kind of buttons.. I have attached a screen shot of what I have..
I think my skin might be different..
sorry i really don't know much about XBMC, thats why i use it, its all just so simple..
Sorry 2secs after i posted that my friend pointed out that it is the night skin.
I looked in the repositry that you posted, and can see night but am unsure what to do with it.
If its a stupid question please ignore I will try searching for it after i make this post..
UserInterface Wrote:I don't have any of those kind of buttons.. I have attached a screen shot of what I have..
Which skin is it and where did you get it from?
amet Wrote:
Awesome!! I have to be honest I didn't try it as the button on both ends normally are not selectable. I guess when I activated that other spot it came on..
Thanks heaps for that!! Been driving me crazy trying to work it out.
I have one last question that I quickly want to ask here as this seems to be the most knowledgeable spot on subs.
Does anyone know of a site that holds what I believe are called hard subs?
Its for when you have a English show that has small amounts of non-english speaking parts. This is so that you only get English subs for just the parts you need. I have looked everywhere for years but have so far only found 2 shows that have this.
UserInterface Wrote:Awesome!! I have to be honest I didn't try it as the button on both ends normally are not selectable. I guess when I activated that other spot it came on..
try opensubtitles or podnapisi website for that. it will say hard subs next to it I think
glad you worked it out
Hi, Im new on this and try to find out on the blog how to configure XBMC subtitles, I installed the addon, and activated on the VIDEO OSD, also I checked if it subs were activated in all places, finally I also checked the video config to discard the chance that the subs were to low to watch them, and still nothing, can´t make the subs work.
On the process the addon locate the subs, download them and when i check, it tells me that they are activated, but nothing happens. On the xbmc. log I got this:
***Log removed***
mendez01 Wrote:Hi, Im new on this and try to find out on the blog how to configure XBMC subtitles, I installed the addon, and activated on the VIDEO OSD, also I checked if it subs were activated in all places, finally I also checked the video config to discard the chance that the subs were to low to watch them, and still nothing, can´t make the subs work.
***Log removed***
Pastebin the full debug log while using the addon
