2011-06-21, 22:36
j777jsy Wrote:Hi Amet et al
I am a XBMC naive person. I will try and explain my problem. I don't get subtitles despite trying few of the options that people have already mentioned..
My debug logs are here
part 1 - http://pastebin.com/TLHThT59
part 2 - http://pastebin.com/1tNXHQmr
I usually stream movies from icefilm rather than downloading it completely. Hence I prefer to have subtitles at the same time. I download the subtitles using podnapisi.net with username and password... it says its downloaded but nothing happens when the movie continues....ie. no subtitles
on the xbmc subtitles setting page under services I have ticked open subtitles.org and subscene.com and undertexter.se
I have also unticked "subtitle download folder same as movie"
downolod folder is /var/mobile/downloads both on the settings and also on system/videos - setting subtitle folder
Dont' know what else to do to get the subtitles..tried a few movies without much effect.
Please help .. Thanks
J
it shows that the srt file has been copied to /var/mobile/Downloads/ but that it couldnt be activated.. that is strange... It would only happen if the srt is invalid(as in not the subtitles file).. what do you have in /var/mobile/Downloads/?
