Full Version: dc:bcm-h264 vs dcz;chd-h264
I am running xbmc compiled from post #28 from this thread http://forum.xbmc.org/showthread.php?tid=66650&page=3
and some 1080 videos play great, including
DivXHD video while other H264 dont play well at all in xbmc. I can play these in windows with media player classic almost flawlessly.
I noticed in the screenshot of this forum that "dc:bcm-h264". While mine shows "dc:chd-h264"
http://www.avsforum.com/avs-vb/showthrea...546&page=3
Is there something I didn't do correctly when compiling xbmc with crystal hd support or do I need to change an option? Will this help me in playing video smoother?
BTW - I have a Dell Mini 9, GMA 950, bcm-70012, Ubuntu 10.04
josh4trunks Wrote:I am running xbmc compiled from post #28 from this thread http://forum.xbmc.org/showthread.php?tid=66650&page=3
name change bcm (broadcom) -> chd (crystalhd)
it would be nice to see the MediaInfo output of those that play in media player classic w/chd but have problems in xbmc.
lol, freaking out over a name change...
Ill get them for you, its weird mp4 play fine in media player classic but horrible in xbmc. I actually tried getting mediainfo earlier but didn't know exactly how. say a site with only karmic builds. ill look into it and post back, thanks
Edit
compiling now, may take a while...
josh4trunks Wrote:lol, freaking out over a name change...
Edit
Does media player classic use crystalhd ?
I'm really dumb, just got it from a ppa...
This plays almost flawlessly in media player classic, but is really bad in xbmc, like 1fps, but when i check my log crystal didn't have errors and is being used
General
Complete name                    : The Bourne Ultimatum - Trailer.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 79.7 MiB
Duration                         : 1mn 29s
Overall bit rate                 : 7 491 Kbps
Encoded date                     : UTC 2007-05-09 07:55:25
Tagged date                      : UTC 2007-05-09 07:55:25
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : [email protected]
Format settings, CABAC           : No
Format settings, ReFrames        : 1 frame
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1mn 29s
Bit rate mode                    : Variable
Bit rate                         : 7 435 Kbps
Maximum bit rate                 : 16.7 Mbps
Width                            : 1 920 pixels
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.198
Stream size                      : 78.6 MiB (99%)
Writing library                  : x264 core 54 svn-635M
Encoding settings                : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=7435 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40
Tagged date                      : UTC 2007-05-09 07:55:30
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 1mn 29s
Bit rate                         : 96.0 Kbps
Maximum bit rate                 : 140 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Stream size                      : 1.01 MiB (1%)
Encoded date                     : UTC 2007-05-09 07:55:29
Same performance with this, stutters only when i skip around in media player classic but barely runs in xbmc. It's an .mkv though
General
Complete name                    : Star.Trek.2009.Bluray.1080p.x264.AC3-METiS.mkv
Format                           : Matroska
File size                        : 8.75 GiB
Duration                         : 2h 6mn
Overall bit rate                 : 9 875 Kbps
Encoded date                     : UTC 2008-03-03 00:17:24
Writing application              : mkvmerge v2.2.0 ('Turn It On Again') built on Mar  4 2008 12:58:26
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                           : AVC
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Muxing mode                      : Container [email protected]
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 6mn
Bit rate                         : 9 038 Kbps
Nominal bit rate                 : 9 232 Kbps
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Bits/(Pixel*Frame)               : 0.245
Stream size                      : 8.01 GiB (92%)
Writing library                  : x264 core 76 r1271 496d79d
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9232 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Codec ID                         : A_AC3
Duration                         : 2h 6mn
Bit rate mode                    : Constant
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Stream size                      : 581 MiB (6%)
Thanks for being willing to help me
davilla Wrote:Does media player classic use crystalhd ?
yeah, it had support for it since late last year
Any idea why those 2 files work good in media player classic but not xbmc? thanks
josh4trunks Wrote:Any idea why those 2 files work good in media player classic but not xbmc? thanks
no
