jmarshall Wrote:http://forum.xbmc.org/showthread.php?tid=75532
Thanks, I went ahead and upgraded my ATi drivers and tried to disable v-sync since I didn't have the catalyst control center installed... but now the XBMC program won't even run at all now. It gives me a unexpected error and shuts down.
00:47:48 T:4092 M:787554304 NOTICE: -----------------------------------------------------------------------
00:47:48 T:4092 M:787537920 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Dec 23 2009 (SVN:26017, compiler 1500)
00:47:48 T:4092 M:787537920 NOTICE: Intel® Pentium® 4 CPU 2.80GHz
00:47:48 T:4092 M:787537920 NOTICE: Desktop Resolution: 1360x768 32Bit at 60Hz
00:47:48 T:4092 M:787537920 NOTICE: Running with administrator rights
00:47:48 T:4092 M:787537920 NOTICE: special://xbmc/ is mapped to: E:\Program Files\XBMC
00:47:48 T:4092 M:787537920 NOTICE: special://masterprofile/ is mapped to: E:\Documents and Settings\Randy\Application Data\XBMC\userdata
00:47:48 T:4092 M:787533824 NOTICE: special://home/ is mapped to: E:\Documents and Settings\Randy\Application Data\XBMC
00:47:48 T:4092 M:787533824 NOTICE: special://temp/ is mapped to: E:\Documents and Settings\Randy\Application Data\XBMC\cache
00:47:48 T:4092 M:787533824 NOTICE: The executable running is: E:\Program Files\XBMC\XBMC.exe
00:47:48 T:4092 M:787533824 NOTICE: Log File is located: E:\Documents and Settings\Randy\Application Data\XBMC\xbmc.log
00:47:48 T:4092 M:787533824 NOTICE: -----------------------------------------------------------------------
00:47:48 T:4092 M:787509248 NOTICE: Setup SDL
00:47:48 T:4092 M:787103744 NOTICE: Found mode: 320x200 @ 60.00 - Full Screen
00:47:48 T:4092 M:787099648 NOTICE: Found mode: 320x200 @ 75.00 - Full Screen
00:47:48 T:4092 M:787099648 NOTICE: Found mode: 320x240 @ 60.00 - Full Screen
00:47:48 T:4092 M:787099648 NOTICE: Found mode: 320x240 @ 75.00 - Full Screen
00:47:48 T:4092 M:787099648 NOTICE: Found mode: 400x300 @ 60.00 - Full Screen
00:47:48 T:4092 M:787099648 NOTICE: Found mode: 400x300 @ 75.00 - Full Screen
00:47:48 T:4092 M:787095552 NOTICE: Found mode: 512x384 @ 60.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 640x400 @ 60.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 640x400 @ 75.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 640x480 @ 60.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 640x480 @ 72.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 640x480 @ 75.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 720x480 @ 60.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 720x480 @ 75.00 - Full Screen
00:47:48 T:4092 M:787091456 NOTICE: Found mode: 720x576 @ 59.94 - Full Screen
00:47:48 T:4092 M:787087360 NOTICE: Found mode: 720x576 @ 60.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 720x576 @ 75.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 800x600 @ 56.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 800x600 @ 60.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 800x600 @ 70.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 800x600 @ 72.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 800x600 @ 75.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 848x480 @ 60.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 848x480 @ 75.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 1024x480 @ 60.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 1024x768 @ 60.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 1024x768 @ 70.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 1024x768 @ 72.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 1024x768 @ 75.00 - Full Screen
00:47:48 T:4092 M:787083264 NOTICE: Found mode: 1280x720 @ 60.00 - Full Screen
00:47:48 T:4092 M:787079168 NOTICE: Found mode: 1280x768 @ 60.00 - Full Screen
00:47:48 T:4092 M:787079168 NOTICE: Found mode: 1360x768 @ 60.00 - Full Screen
00:47:48 T:4092 M:787116032 NOTICE: load settings...
00:47:48 T:4092 M:787103744 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:47:48 T:4092 M:787103744 NOTICE: loading special://masterprofile/guisettings.xml
00:47:48 T:4092 M:786587648 NOTICE: Getting hardware information now...
00:47:48 T:4092 M:786587648 NOTICE: Checking resolution 12
00:47:48 T:4092 M:786575360 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
00:47:48 T:4092 M:786563072 NOTICE: Loaded playercorefactory configuration
00:47:48 T:4092 M:786554880 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
00:47:48 T:4092 M:786554880 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:47:48 T:4092 M:786554880 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
00:47:48 T:4092 M:786554880 NOTICE: Default DVD Player: dvdplayer
00:47:48 T:4092 M:786554880 NOTICE: Default Video Player: dvdplayer
00:47:48 T:4092 M:786554880 NOTICE: Default Audio Player: paplayer
00:47:48 T:4092 M:786685952 NOTICE: special://masterprofile/sources.xml
