Full Version: Revo R3610 hdmi Pass through audio problem R3600 np
Hello,
I hoping one of the gurus here can help me with this strange problem.
I own two Revos one is a R3600 and another which I recently got is a R3610.
They are both almost identical with only difference being 3610 has a dual core cpu, bit more ram (so I can set 512M to GPU in bios rather than 256M), and a SPDIF output.
I have been using the R3600 for a while now and have quite a few independant OSs running on it including two builds of XBMCbuntu karmic one running a stable build of xbmc and the other svn28256.
The sony tv I use can handle ac3 so i use ac3 pass through over hdmi. Works great with R3600.
Ok so clone my builds onto new R3610 other than few fiddles with the network card should be fine I am thinking.
However now I all I get using hdmi ac3 pass through is a kind of static sound into the tv. Normal hdmi sound works fine just the pass through does not work. This happens both on the stable and svn build I am using.
R3600 aplay output:
card 0: NVidia [HDA NVidia], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 3: NVIDIA HDMI [NVIDIA HDMI]
Subdevices: 0/1
R3610 aplay output:
**** List of PLAYBACK Hardware Devices ****
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 1/1
Subdevices: 0/1
Currently using asound.conf of
pcm.!default hdmi:NVidia
although I've tried many different ones including the xbmc freak to ouput everything.
http://www.xbmcfreak.nl/wp-content/uploa...oundrc.txt
Any ideas on how to proceed?
