Full Version: System hangs on resume (not every time)
I have Zotac MAG with XBMC Live installed + IR receiver with MCE remote. Everything is configured and works fine. I can suspend/sleep and wakeup/resume the system from the remote.
At least this is how it used to work until a couple of weeks ago. Now after I wakeup/resume the system for 2nd or 3rd time, it does not want to come back - it hangs and the only way to reset it is to disconnect and re-attach the power cord.
Does anyone have any idea what causes this and if there is a way to fix it?
Otherwise I probably would need to keep the system running 24/7...
Does anyone have an idea about this problem?
Mine resumes, but hangs sometimes when starting video, or scanning library. though it usually comes back after some time
