Full Version: Problem Install Plugin
Hello,
In C: \ Documents and Settings \ [user name] \ Application Data \ XBMC \ plugins \ Program
I copied the plugin.
If I add the XBMC-> Programs-> Add Source going, I can select the source folder and see only the folder structure and not the default.py
It is then only added to the folder but not the program?
XBMC Version: Rev3100 (with DSPlayer)
OS: Windows XP SP3 (German)
Sorry for my bad Englisch *g*
hi,
i think you meant rev 31000. if so, there is a new addon system implemented in xbmc and as far as is know old plugins/script/addons won't work anymore.
in upcoming xbmc you can download/activate/configure addons in system - add-ons. by now there are already some plugins available but, for me, most interesting addons are still missing.
if you want to manually add a (new) plugin you have to copy it to .... XBMC\addons\ (don't know the exact path for windows)
in linux it's ~/.xbmc/addons/
e.g. apple movie trailers lite is already updated
http://forum.xbmc.org/showpost.php?p=554...tcount=344
