Hey all,
I have a strange problem with my XBMC (R28042) on Ubuntu Minimal 10.04 (Lucid).
After I tried to install a svn-build, the function for reboot / shutdown doesn't work like I guess (that only xbmc quits and the tty-loginscreen is active). When I press the buttons for shutdown / reboot its quit XBMC and restart it immediately. The suspend-button has no function, but this doesn't interesst....
How can I fix my button-problem?
And is the XBMC-Version realy up-to-date? Or did I some misstakes on installing XBMC from svn?
here a summary of my installation-way:
install xbmc like it is describe in this
HOW-TO for Ubuntu minimal
but change the repo to ppa:team-xbmc-svn/ppa
after this I tried to make an svn build:
get sources via svn, install some tools which are needed according to the booth readmes in the svn-folder
./bootstrap
./configure
make
make install
is this procedure right?
thx for some helpfull answers
bye...
netdive
Have the same problem. When I press the buttons for shutdown / reboot its quit XBMC and restart it immediately.
This is what is did before it started happening: Updated via de XBMC SVN PPA Karmic and updated the XBMC live CD Camelot to Linux 2.6.31-16 and XBMC PRE-10.5 r28256 (Compiled March 1 2010).
Hopefully someone can help us fix this.
neil.j1983 Wrote:http://forum.xbmc.org/showthread.php?tid=75565
have you tried that?
or better yet, post a log for the devs.
Thanks for the info. Tried it, but doesn't work
Here the only info i could get from the xbmc.log. As it doesn't crach, no crashlog is available.
12:59:30 T:3077625728 M:1423577088 DEBUG: LIRC: Update - NEW at 41489:000000037ff07bdd 00 OK mceusb (OK)
12:59:30 T:3077625728 M:1423577088 DEBUG: OnKey: 11 pressed, action is Select
12:59:30 T:3077625728 M:1423577088 DEBUG: ExecuteXBMCAction : Translating XBMC.Shutdown()
12:59:30 T:3077625728 M:1423577088 DEBUG: ExecuteXBMCAction : To XBMC.Shutdown()
12:59:30 T:3077625728 M:1423577088 DEBUG: CAnnouncementManager - Announcement: ApplicationStop from xbmc
12:59:30 T:3077625728 M:1423577088 NOTICE: Storing total System Uptime
12:59:30 T:3077625728 M:1423577088 NOTICE: Saving settings
12:59:30 T:3077625728 M:1423450112 NOTICE: stop all
12:59:30 T:3077625728 M:1423450112 DEBUG: NetworkMessage - Signaling network services to stop
12:59:30 T:3077625728 M:1423450112 NOTICE: ES: Stopping event server
12:59:30 T:3077625728 M:1423450112 DEBUG: CZeroconfAvahi::doRemoveService named: servers.jsonrpc
12:59:30 T:3077625728 M:1423450112 DEBUG: NetworkMessage - Waiting for network services to stop
12:59:30 T:3077625728 M:1423450112 NOTICE: stopping upnp
12:59:31 T:2961156976 M:1423642624 NOTICE: ES: UDP Event server stopped
12:59:31 T:2961156976 M:1423642624 DEBUG: Thread 2961156976 terminating
12:59:31 T:2950667120 M:1423630336 DEBUG: Thread 2950667120 terminating
12:59:31 T:3077625728 M:1423630336 NOTICE: stopping zeroconf publishing
12:59:31 T:3077625728 M:1423630336 NOTICE: Webserver: Stopping...
12:59:31 T:3077625728 M:1423630336 NOTICE: WebServer: Stopped the webserver
12:59:31 T:3077625728 M:1423630336 NOTICE: Webserver: Stopped...
12:59:31 T:3077625728 M:1423630336 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
12:59:31 T:3077625728 M:1423630336 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
12:59:31 T:3077625728 M:1423630336 NOTICE: stop dvd detect media
12:59:31 T:101854064 M:1423630336 DEBUG: Thread 101854064 terminating
12:59:31 T:3077625728 M:1423630336 NOTICE: stop sap announcement listener
12:59:31 T:3077625728 M:1423630336 NOTICE: clean cached files!
12:59:31 T:3077625728 M:1423630336 NOTICE: unload skin
12:59:31 T:3077625728 M:1423630336 DEBUG: CGUIAudioManager::DeInitialize
12:59:31 T:3077625728 M:1423630336 DEBUG: ------ Window Deinit (Home.xml) ------
12:59:31 T:3077625728 M:1423630336 DEBUG: ------ Window Deinit (Pointer.xml) ------
12:59:31 T:3077625728 M:1423630336 DEBUG: ------ Window Deinit (DialogMuteBug.xml) ------
12:59:31 T:3077625728 M:1432264704 INFO: CrystalHD: device closed
12:59:31 T:3077625728 M:1432264704 NOTICE: stop python
12:59:31 T:3077625728 M:1432264704 NOTICE: stopped
12:59:31 T:3077625728 M:1432264704 NOTICE: destroy
12:59:31 T:3077625728 M:1432264704 NOTICE: unload sections
12:59:31 T:3077625728 M:1432264704 DEBUG: SECTION:UnloadAll(DLL: libcurl.so.4)
12:59:31 T:3077625728 M:1432264704 DEBUG: Unloading: libcurl.so.4
12:59:31 T:3077625728 M:1432264704 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
12:59:31 T:3077625728 M:1432264704 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
12:59:31 T:3077625728 M:1432264704 DEBUG: object 0 --> 0 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 1 --> 1 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 2 --> 13 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 3 --> 0 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 4 --> 10 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 5 --> 0 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 6 --> 0 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 7 --> 0 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 8 --> 0 instances
12:59:31 T:3077625728 M:1432264704 DEBUG: object 9 --> 0 instances
If the reboot or shutdown is activated from XBMC, a small black X (mouse cursor) appears and XBMC is restarted. Something tells me this could be caused by Xserver/X11.
Tried diffrent Nvidia drivers, but didn't help either.
Fixed it for shutdown and reboot;
PHP Code:
[Actions for xbmc user]
Identity=unix-user:xbmc
Action=org.freedesktop.devicekit.power.*;org.freedesktop.consolekit.system.*
ResultActive=yes
ResultAny=auth_admin
ResultInactive=yes
Paste the above text into
sudo nano /var/lib/polkit-1/localauthority/50-local.d/custom-actions.pkla
then I
sudo apt-get remove policykit-1
sudo apt-get remove devicekit-power
then reboot.
For the Exit button; gives me weird green blue and red stripes.
The stripes happened to me when I upgrade nvidia drivers without removing the old ones properly. Since then I have always installed the nvidia beta ones on a fresh system (no previous nvidia drivers, ever). Solved my issues.
neil.j1983 Wrote:The stripes happened to me when I upgrade nvidia drivers without removing the old ones properly. Since then I have always installed the nvidia beta ones on a fresh system (no previous nvidia drivers, ever). Solved my issues.
The XBMC Live CD comes with Nvidia Drivers. How did you do that?
