Full Version: How to change the MPAA rating image to non-US (Australian)
Not sure if confluence skin is the right location, but here goes.
Based as I am in Australia, it would be great if it was possible to change the displayed MPAA rating from US to Australian.
Using the right scraper (and ember media manager) I can get that info into a .info for the movie with no problems.
Updating XBMC will also update the text MPAA rating to show the Australian equivalent (ie M rating, instead of R, etc)
However the associted MPAA icon will disappear when using an appropriate view like FanArt
I'm hoping this is just due to the skin not having correct icons for the Australian equivalent.
Is it possible to have the correct Rating icon displayed?
Unfortunately its just not as simple as having the right images the rating tags are a hack at best and only really work with imdb if you want to add more you can edit IncludesCodecFlagging.xml @ line 70 and add your extra images
ignore. i don't read replies properly Smile
Thanks Jezz_X
