HydroDiOxide Wrote:Ah. That is a whole lot better. Still, as a consistency nitpick, the positioning of time and date is different in home and (movie)library. Also the colour of day and date differ (white vs blue). Is this intended or overseen? Hey, and turning the volume all the way down seems to produce a different type of mute icon. This one overlaps with track playtime.
Allright, the mute icon overlapping should finally be fixed now, pushed to git.
I made the date and time all white for the sake of readability. Not sure about the positioning though, they should be at the same position?
Rocky5 Wrote:I think for the visible labels on the home screen you could do what I done (when I fixed it) & make the select image fade out like when idling.
Cheers, I pushed an update yesterday which basically does the same, but making the selection image fade out is a nice extra touch.
Quote:also do you have any use for Recently added on the home screen? as I incorporated that in two days ago.
I'm not sure, I tried out something similar way back. To me it takes about the same amount of steps to go into "new movies/episodes" from the main menu, with the benefit of having all info available. I guess I'm not really a big fan of bringing everything onto the homescreen, and creating a sort of mini library there. But nice job, I'll still give it a thought.
Quote:I also fixed the intro, you had the black image behind the video, so the it never looked like it fades out, I also had to increase the duration as on my Revo it would end to soon, so I delayed the startup of the video by 500ms and increased the duration to 6500ms fixing the problem.
(I have also redone the intro using images, using the correct fonts) Youtube Video
Nice work, I'll take a look at tweaking the delay/duration.
kyotocafe Wrote:Current watchlist implementation works pretty good to me, but I agree that this way you have just proposed feels more intuitive. It would be nice to have it implemented in git and try it out.
I'll work on it some more and post it to try out if I decide to go through with it
loggio Wrote:Hi jeroen,
Not sure if you're aware, but i've created a 'hd movies' smart playlist... When i access it using refocus, theres no Thumbnail or slide views... The two views i only use lol
Right, should be fixed on git. Cheers
Quote:Also turns out cinema experience is buggy as all hell and has nothing to do with your skin, so false alarm on that one! lol
That's reassuring
Hope it gets more stable soon.
spoco2 Wrote:Awesome, you've added 'exit' back to the homescreen...
Life is good once again
I have to say, I try other skins every now and again, and while they are very competent, and sometimes have some pretty cool animations and layouts, they all come across as being created by people with the sensibilities of a 12 year old. This really is the only 'mature' skin I've used.
Thanks, sensible design/development is definitely something I try to achieve with reFocus, although it's a bit harsh towards other devs.. Different preferences for different people, there's something there for everyone
epoke Wrote:Korean translation for 0.9.4.1
strings.xml
Awesome, thanks epoke. Pushed to git, cheers
Galefury Wrote:I really like the watchlist, but I've noticed that for tv shows while the season is correct, the episode is always 05, though it will play the correct one.
LE: I've got it. It shows the last episode of the last tv show watched. If my last episode was dexter s04e5, then it will display ep 5 for all the shows, though the season will be accurate.
Hm, that would be something to report to the add-on devs, it's handled by the add-on. I'll see if I can reproduce.
