canadave Wrote:Wow, I don't see any of that at all in IncludesFlags.xml I just downloaded the latest git version, and this is the entire content of that file:
http://pastebin.com/mrACj6JM
I'm using an old 0.9.3 build so it might have moved since then? Not sure on what the contents of the current ones look like.
loggio Wrote:Now that's more like it!! lol great
Indeed, looks fantastic so far!
wolfodeiwolfy Wrote:Thanks, I'll give you another version later because some words were not translated (because I don"t know at this time what they mean)
Oh, just give me the string ID's and I'll tell you what they mean and where they are used
Regarding translations, it's just grabbing the English XML from github and translating it, right? I could do a pt_PT (European Portuguese) translation, as I do not think there's any.
the epg looks amazing, hope you continue with the pvr support!
Hi Jeroen, here are the italian string:
http://pastebin.com/0Fsn1XY3
ps: I don't understand what is "smooth scrolling". I will post an updated translation when i see the meaning.
samukas Wrote:Regarding translations, it's just grabbing the English XML from github and translating it, right? I could do a pt_PT (European Portuguese) translation, as I do not think there's any.
Yup, that's about it. Also, providing a translation for a couple of strings in addon.xml would be great
There's no Portuguese translation yet, so that would be most welcomed.
wolfbiker Wrote:the epg looks amazing, hope you continue with the pvr support!
Oh I will definitely. It can just be a bit frustrating at times
henrava Wrote:Hi Jeroen, here are the italian string:
Smooth scrolling is an option in skin settings. If you turn that on, the scrolling from one item to another in list views will be animated. When disabled it just skips from item to item right away. Turn it on and go into your movies or shows and set the view to list, you'll see what I mean.
Thanks for the translation, much appreciated
First of all i would like to say that i Love reFocus. Its just so elegant and simple!
Thanks to Everyone involved.
I'm currently running Eden and tried to install the latest build from the zip-file but it keeps failing. Also if I add your repo it's just empty for me.
Any clue what I'm doing wrong here?
Trying out this skin and loving it so far
I've got a few questions though.
1: How can I get an addon directly under the add-on menu? I saw in the customize home menu skin setting that there is a setting for add-on 1, 2 etc but it never gives me the option to actually select an addon, just entering a label or something that doesn't do anything. Am I missing something here or are you supposed to go to your addons through addons>programs>tv show - next aired.
2: I've been digging through the xml's to get a Radio submenu under live tv, but without success. Any chance you can point me in the right direction in what files I should be editing? To me it seems like the pvr part handles the Radio section differently than the TV Channels section, or i'm just looking at the wrong files
maxsql Wrote:First of all i would like to say that i Love reFocus. Its just so elegant and simple!
Did you try refreshing by rightclicking on the repo?
Quote:After looking at the Thumbnails view, it appears that fanart is used for the artist thumbnails, rather than the folder.jpg. Is there anyway to change this?
The thumbnails view uses the artist thumbs, not the fanart.
Looking at this again, fanart.jpg is definitely used instead of folder.jpg for the thumbnails in Library mode. Is there anyway to change this, rather than manually setting the fanart to folder.jpg instead?
This is my favorite skin, but (for me at least) it's very unstable. Does it freeze a lot for anyone else? It seems if there is a window with a 'cancel' button, you can never actually cancel.
I see it now in the repo but I always get "installation failed"
Anyone got an idea?
I forgot to mention: I'm using an ATV 2 (4.4.4) with the Eden beta
Edit: the "trick" uninstalling and reinstalling doesn't work
now I can't even use refocus
