is this being worked on anymore? not a fan of refocus big.
(2013-03-17, 14:12)moontan77 Wrote: [ -> ]is this being worked on anymore? not a fan of refocus big.
Hi, it is being worked on, albeit slowly. It's basically in maintenance mode, making sure it stays compatible with XBMC milestone releases. I would like to do more, but time is simply not in high supply. But I just finished skinning my living room, which should make it a bit easier to find time to work on reFocus
glad to hear it's not dead - I'd love to see a Frodo version
Im also big fan of Original Refocus.. Hope so u will get stable version released.
btw in git version here is still music playing bug (Time dont showing in right up corner)
(2013-03-17, 15:41)Jeroen Wrote: [ -> ] (2013-03-17, 14:12)moontan77 Wrote: [ -> ]is this being worked on anymore? not a fan of refocus big.
Whoa! Jeroen himself! It's freaking awesome to see you replying posts, but even more to read that you're still working on reFocus.
(2013-03-17, 21:28)ZZRX Wrote: [ -> ]Im also big fan of Original Refocus.. Hope so u will get stable version released.
Could you tell me some more about this? In which screen? Cheers
I might chime in here while we've got you Jeroen.
Just a reminder, OSD live tv info does not show anymore when pushing up/down to change channels. "show channel info when switching channels" in live tv settings.
This is the only reason i'm using refocus Big, because it allows me to use the realaska OSD info, which does this function.
Otherwise refocus big is useless to me.
Cheers Jeroen,
Happy skinning.
loggio.
Is here way how to take screenshot in xbmc? Anyway normal if i click some music track and begin listen, here is in right up corner countdown where is track name and time how long is left. In Frodo here is track name but countdown timer is stuck, track is playing fine, but timer dont move forward.
Dont know is it common problem or is it just my problem, but Eden worked fine.
(2013-03-18, 19:04)Jeroen Wrote: [ -> ] (2013-03-17, 21:28)ZZRX Wrote: [ -> ]Im also big fan of Original Refocus.. Hope so u will get stable version released.
Welcome back, jeroen. Here a bug for you: when there's no album scaned in library, weather info overlaps with movie info. See below.
(2013-03-18, 21:45)baruchin Wrote: [ -> ]@Jeroen, could you please check this issue? http://forum.xbmc.org/showthread.php?tid...pid1364756
I can't reproduce this problem. I installed the add-on you're using in the screenshots and it's showing movie posters for me in all views.
(2013-03-19, 16:25)loggio Wrote: [ -> ]I might chime in here while we've got you Jeroen.
Cheers Jeroen,
Happy skinning.
loggio.
I don't have a PVR setup at the moment, but I'll check every part of PVR once I do.
(2013-03-19, 16:42)ZZRX Wrote: [ -> ]Is here way how to take screenshot in xbmc? Anyway normal if i click some music track and begin listen, here is in right up corner countdown where is track name and time how long is left. In Frodo here is track name but countdown timer is stuck, track is playing fine, but timer dont move forward.
Sorry, but I can't reproduce this. More people with this problem?
(2013-03-19, 18:08)Galefury Wrote: [ -> ]Welcome back, jeroen. Here a bug for you: when there's no album scaned in library, weather info overlaps with movie info. See below.
This should be fixed on git, but I'm not sure if that won't cause other problems
(2013-03-21, 22:11)Jeroen Wrote: [ -> ] (2013-03-18, 21:45)baruchin Wrote: [ -> ]@Jeroen, could you please check this issue? http://forum.xbmc.org/showthread.php?tid...pid1364756
Weird. I've installed the latest git and still this problem in an Apple TV and Windows 7 pc. What could it be?
(2013-03-21, 22:57)baruchin Wrote: [ -> ] (2013-03-21, 22:11)Jeroen Wrote: [ -> ] (2013-03-18, 21:45)baruchin Wrote: [ -> ]@Jeroen, could you please check this issue? http://forum.xbmc.org/showthread.php?tid...pid1364756
Reporting in this issue, I downloaded the March 26 commit and it seems that it's fixed, thanks! Now when I go to seasons while in list view I get this double cover image.
So, I don't know if this is going to lead to anything permanent but I've been revisiting some old ideas for a new/alternate homescreen.
The fanart / bottom part is scrollable, it shows recent or recommended items
This is either going to be a complete replacement or alternative choice. In the latter the goal is to have all currently existing homescreen customizations brought over to the alternate.
Far off from completion.
