TC!! Wrote:I'm having a problem with 0.9.1, I can't get browse to work in videos, forces library mode. If I switch to a different skin like neon then it's fine. Also don't see any options to add source.
You're not running a nightly build. Please see thread title and first post.
BigDaddyRal Wrote:Aside from being visually attractive, I enjoy being able to see all that info if I'm coming back from an extended time away. Particularly the Finish Time.
finish time is shown on pause
Just installed and it looks and works great! Except I do have one little problem...
When my current selection in episode list is the "parent folder" or "..", I see the following jumble:
Any idea why that would happen? When I move the selection down to an episode it looks good.
Any update on the "unwatched label/tag"? I'd prefer that as well
Jeroen Wrote:10 seconds? Wow, this has me baffled to be honest. Is Quartz on a nightly build as well?
I'm afraid so. And Quartz is blazing fast.
Jeroen Wrote:You're not running a nightly build. Please see thread title and first post.
Turns out I'd found the right way to update XBMC but my Ubuntu system was too old to get the latest versions, updating now.
Thanks for the quick reply and the great skin!
harry3001 Wrote:slight text overlap in the title of the video playlist screen
<img src="http://i.imgur.com/UnJHH.jpg" alt="" title="Hosted by imgur.com" />
I've not been able to reproduce this. Make sure you're using a nightly xbmc build. If you are please provide a step by step direction on how you access this screen.
ekimneems Wrote:When my current selection in episode list is the "parent folder" or "..", I see the following jumble:
I have no idea, I have not been able to reproduce this. In your screenshot the second line show the tvshow title, where it should show the episode and season information, plus the rating stars are not shown. Are you using any mod/modification? If not, it may be best to completely remove the skin and reinstall.
TC!! Wrote:Turns out I'd found the right way to update XBMC but my Ubuntu system was too old to get the latest versions, updating now.
Allright, np
MaDDoGo Wrote:Do you have this img to change it? or the psd file to addapt the + icon to this?
Sorry, forgot about this last night:
I couldn't find the psd, so I'm afraid I don't have it anymore.
Doraemonn Wrote:I'm afraid so. And Quartz is blazing fast.
Could you try downloading
this zip
Inside is an addon.xml, place this in the root of the skin.refocus folder, and a viewsvideo.xml, place this one in the 720p folder and backup the old viewsvideo.xml. Relaunch XBMC
Could you then try if this makes any difference whatsoever in list view? Other views won't see any effect.
Don't worry if things don't look right, this is purely a test.
People with no performance issues: using these files will only screw things up for you.
Jeroen Wrote:I have no idea, I have not been able to reproduce this. In your screenshot the second line show the tvshow title, where it should show the episode and season information, plus the rating stars are not shown. Are you using any mod/modification? If not, it may be best to completely remove the skin and reinstall.
I did a complete uninstall of XBMC including my profile folder. Reinstalled with a fresh nightly build (6-17). Then dropped the skin.refocus folder in my addons folder. Same thing is happening! Very Strange. FYI this also happens with "Big List" view as well.
Could it be the way I installed it? It won't let me install with Install from Zip because it says "Dependencies Not Met"
Thank you very much Jeroen. I have a question. What is the name file and the location of the unseen png?
PS: Another question (XBMC Related). In the movies, shows or episodes info view there's the left key menu. This menu is hardcoded or skin coded? If it is skin coded, there's a change you can add the banner, logo, thumbnail, etc options in adition to the fanart and thumb ones?
ekimneems Wrote:I did a complete uninstall of XBMC including my profile folder. Reinstalled with a fresh nightly build (6-17). Then dropped the skin.refocus folder in my addons folder. Same thing is happening! Very Strange. FYI this also happens with "Big List" view as well.
I guess u should just extract the skin into the addons folder and see what happens.
MaDDoGo Wrote:Thank you very much Jeroen. I have a question. What is the name file and the location of the unseen png?
The name of the file is overlayunwatched.png and its location is in root of the textures.xbt. You'll have to pack it as xbt and drop it in the media folder.
Here, you can use mine. Copy it in the media folder then go to settings/appearance/skin/theme and choose "silverstar." The result is this:
Jeroen, thank you so much for posting the unwatched file, it looks better than the default one, it's more stilish, in tone with the skin.
Your work is awesome ! This i a very good design.
In my mind it looks professional, clean and easy to navigate.
When this skin is out of beta it should be xbmc default skin, it's miles ahead from
the default confluence which i think doesent fit as a default skin.
Re-Focus should in time become the default skin.
Thanks for your exelent work and for giving me the best xbmc skin to date !
bandelguy Wrote:I guess u should just extract the skin into the addons folder and see what happens.
Yeah, that's what I did. I was just wondering if the "dependencies not met" error when trying to install from the zip file was maybe a clue as to why this was happening? Or should I expect it to not work like that because we're using nightlies?
