A beta tester listed this as an issue:
"My biggest problem so far is when I'm navigating to and from the Home screen. The transition has no smoothness and it also takes about 2 seconds. When in 'Movies' and returning to 'Home' (pressing esc) I see the Video-backdrop for about 1-2 secs before being returned to the Home screen."
I have looked and I have a window open and close animation set to fade in but it doesnt happen smoothly?
What file should I have the animation in to make moving to and from the home screen a smoother transition?
remove the recently added python script probably or don't run it when you enter home
Jezz_X Wrote:remove the recently added python script probably or don't run it when you enter home
It runs when XBMC is started how do I check if it is running when entering home? Here is how it is in home.xml. (should look familiar to you Jezz)
<include condition="Skin.HasSetting(homepageHideRecentlyAdded)">HomeRecentlyAddedInfo</include>
<control type="button" id="8999">
<description>Run Recently added</description>
<posx>-20</posx>
<posy>-20</posy>
<width>1</width>
<height>1</height>
<label>-</label>
<font>-</font>
<onfocus>XBMC.RunScript(special://skin/scripts/RecentlyAdded.py,limit=8&totals=True&albums=True&unplayed=True)</onfocus>
<onfocus>SetFocus(9000)</onfocus>
<texturenofocus>-</texturenofocus>
<texturefocus>-</texturefocus>
<visible>Skin.HasSetting(homepageHideRecentlyAdded)</visible>
</control>
<description>Don't run Recently added</description>
<posx>-20</posx>
<posy>-20</posy>
<width>1</width>
<height>1</height>
<label>-</label>
<font>-</font>
<visible>!Skin.HasSetting(homepageHideRecentlyAdded)</visible>
</control>
Do you know that recently added is the cause?
What happens where if you disable it, if you have a setting...Or just outright delete the recently added code do you still have the same behavior?
mcborzu Wrote:Do you know that recently added is the cause?
I turned it off and I still get the delay.
then its probably your animation code the window is waiting for a animation to finish before it closes
