Hello,
I have an issue with the builds r31168 and r31198, if I want put a new movie in the database. I see than following message.
"Couldnot download information Server ist most likely unavailable"
The serie scraper works without issues.
If I use the build r31139 all works fine.
It's the same issue with windows7 and appleTV.
Can somebody confirm this?
Greets
Guido
Same here...saw the new ver on launcher for ATV, installed and can't scrape due to same error.
Yeah I have the same problem. Any solutions ?
I have the same problem, but my symptoms are opposite: I can't scrape TV using TheTVDB, but IMDB for movies work fine...
Running 31236.
Somebody post here when the newest nightly fixes this so I can continue updating... for now I'm back on an old build...
clock2113 Wrote:Somebody post here when the newest nightly fixes this so I can continue updating... for now I'm back on an old build...
Which?
I just updated to 31236 and it works fine now.
D-tyme Wrote:I just updated to 31236 and it works fine now.
Have test build 31236 for windows with same issue:mad:
31236 is working for me scrapping Movies but TV Shows do not work.
I've tried to update the TV add-on but had no success
I've only tested Movies with 31236 on my ATV, as I don't have any TV Shows ripped. I can't speak to any other platform.
same issue, using DX build 31227 on windows 7
D-tyme Wrote:I've only tested Movies with 31236 on my ATV, as I don't have any TV Shows ripped. I can't speak to any other platform.
Can confirm that 31236 works fine on my ATV, too
I was looking at the Changelog for the new build (31262) and it seems that the problem with TVdb was fixed on the revision 31240 (see below).
I'll try the new build tonight when I return from work.
Revision: 31240
Author: jmarshallnz
Date: 2010-06-20 09:15:46
Modified: /trunk/addons/metadata.tvdb.com/tvdb.xml
fixed: tvdb.com scraper wasn't creating the XML we were expecting in CreateSearchURL
