2010-06-19, 14:14
Hey guys,
I've recently been doing some major tinkering with my XBMC setup, including the installation and integration of an old Xbox DVD remote to control my Windows setup (which is now working great ). Along the way however, I ran into a few unrelated problems, and decided that the best/easiest way to solve them was to completely re-install XBMC.
Since having done that however, I seem to have created some bigger headaches for myself. Specifically, I'm no longer able to perform a "Set Content" on either my "Movies" or "TV" sources. In my "Videos" menu, I have two sources: One named "Movies" (pointing to a single folder containing all my movie files, no sub-folders) and another named "TV" (similarly pointing to a folder with all my TV shows in it, all of which ARE in sub-folders). When a bring up the context menu for either of these sources and press "Set Content", I'm able to go through and select all the relevant settings. However, when I press OK, none of these settings save and the "content" of the folder reverts automatically back to "none".
How can I get the folders to save their "Set Content" setting?
I'm using a nightly build of XBMC (rev.31123) and the Aeon Hitched skin (if any of that info is useful).
Sorry that this is a bit of a noob question, but I'm really stumped!
Cheers,
Ben.
Cheers,
Ben.
