Full Version: nightlies - scraper issues
Hi.
I'm using svn 31200 atm but the problem existed with the version before also.
Here's a part of the log:
http://pastebin.com/NUASkR7x
The effect is, that a windows is shown with "server most likely unavailable" and you get asked if you want to continue scanning.
Does apply to tvdb, imdb and themoviedb. Didn't test any other scraper.
Does not happen with any movie, but with around 10% of my movies.
Sometimes it just says in the log "Unable to parse xml", and now it sometimes just gives empty results. (see log above)
best regards
checkup Wrote:Hi.
best regards
same issues here http://forum.xbmc.org/showthread.php?tid=75907
