2010-06-19, 19:28
2010-06-24, 12:53
costa Wrote:as the title says !
Why ?
Search, then search again.... the answer exists, your quest my friend, is to find it.
2010-06-24, 15:42
Cause it's not compatible with the new addon directory (a skin is now considered as an addon like a scrapper, ...)
2010-06-30, 22:41
Well the skin IS compatable and we will update the official SVN version asap with the update. Possibley this coming weekend.
2010-07-07, 20:32
Sorry to sound stupid but I used to get my updates for this skin via the actual program in the SVN repo thing, well that appears to have disappeared so how do I actually get the update?
My main rig is still running an older XBMC because I cannot be without Ellipsis.
p.s. what happened to your forum?
2010-07-07, 22:53
garyi Wrote:Sorry to sound stupid but I used to get my updates for this skin via the actual program in the SVN repo thing, well that appears to have disappeared so how do I actually get the update?
With regards to the SVN repo thing, not a clue what happened to that, you'll have to ask some XBMC folks.
Our forum was becoming such a hassle to use, because we where getting spammed daily and it became obvious that the annoyance was out-weighing the usefulness of that forum, so we decided to just use XBMC.orgs sub-forums, after all they gave us our own sub-forums for a reason!
2010-07-08, 07:54
So from that can I assume the update is not ready yet for this new plugins thing?
2010-07-12, 15:31
I noticed a skin.xml file after checking out the skin from SVN. Does this mean it should work?
It's not on either of my XBMC installs - one a nightly build from just a few days ago. Assuming it should work, anyone know how to get it appearing?
2010-07-12, 15:45
Skin.xml is for old builds.
Addon.xml is for new builds.
Make yourself an addon.xml see confluence for example.
Skin will work but will not have the addon features
2010-07-12, 15:58
Good grief
addon.xml
Name the ellipsis folder "skin.ellipsis" and stick it in addons
You only have to look to find the answers
http://forum.xbmc.org/showthread.php?tid=74818
addon.xml
<?xml version="1.0" encoding="UTF-8"?>
<addon
id="skin.ellipsis"
version="2.2"
name="Ellipsis"
provider-name="Team Blackbolt">
<requires>
<import addon="xbmc.gui" version="2.11"/>
</requires>
<extension
point="xbmc.gui.skin"
defaultresolution="720p"
defaultresolutionwide="720p"
defaultthemename="textures.xbt"
effectslowdown="1"
debugging="false"/>
<extension point="xbmc.addon.metadata">
<summary>Ellipsis skin by Team Blackbolt</summary>
<platform>all</platform>
</extension>
</addon>
2010-07-13, 12:57
Yeah, I did find the answer thanks (before I read your post I would add )
This is a fantastic skin - don't know why I hadn't used it before. Very polished and complete (except for Add-ons support of course ).
Any plan to get it added as an official Add-on in the XBMC repository?
2010-07-13, 22:56
Only reason we haven't released the update yet is because were adding some more stuff first.
2010-07-14, 00:00
Yeah Blackbolt, I wanna see a bombastic update from you, which will stop our breathing for few seconds !
