silvine Wrote:Is there any progress on Couch Potato renaming existing movies?
What's your problem? I spent a good amount of time in the IRC channel and got quite a bit of help. The renaming function should have a ton of try/catch and debugging.
Sure this has probably been asked before, but any plans to implement 'collection' style features?
Such as download all movies with an actor/actress that aren't in your collection, or a certain director, or even a certain genre (maybe with multiple filters ie all sci-fi by Spielberg for example)?
tboooe Wrote:Thank you sir. I followed these exact steps multiple time with no luck. There is nothing in my log...do I need to download python first?
No, you don't. Because it is contained within the CouchPotato.exe
I can't for the life of me figure out how to use this. I've got the webpage up and running and searched for a couple of movies, but I can't get it to download an NZB. This is probably because I can't work the "providers" config. I'm a member at nzbmatrix but not a VIP, so I have no API. Then nzbs.org isn't taking registrations so that one is also out. And newznab is a complete headfuck, with instructions that include the phrase "create website". Er... ok. Will I be able to get CP to work do you think?
TheStretchedElf Wrote:I can't for the life of me figure out how to use this. I've got the webpage up and running and searched for a couple of movies, but I can't get it to download an NZB. This is probably because I can't work the "providers" config. I'm a member at nzbmatrix but not a VIP, so I have no API. Then nzbs.org isn't taking registrations so that one is also out. And newznab is a complete headfuck, with instructions that include the phrase "create website". Er... ok. Will I be able to get CP to work do you think?
Create a nzb.su account, fill in the host for newznab option as nzb.su and the api key page link is available at the bottom of the page once you are logged into the site.
Will CP shutdown if I close my browser?
TheStretchedElf Wrote:Will CP shutdown if I close my browser?
No, it will not. It runs separately from your browser.
I've got the same issue that a few other posters have had earlier in this thread, but can't seem to figure it out:
16:41:13 ERROR [ ENGINE] Shutting down due to error in start listener:
File "..\build\pyi.win32\CouchPotato\outPYZ1.pyz/cherrypy.process.wspbus", line 213, in start
File "..\build\pyi.win32\CouchPotato\outPYZ1.pyz/cherrypy.process.wspbus", line 193, in publish
ChannelFailures: IOError("Port 5000 not free on '0.0.0.0'",)
I have ran netstat -a -b and there is nothing running on port 5000. I've tried numerous other ports with no change in results. I've tried inputting "localhost" as well as the server's actual IP "192.168.1.50" with no change either.
The interesting thing is that going back through the logs, this isn't the first time its happened, and the next try, CP would start again. That doesn't seem to be the case anymore. A similar issue exists for me with Sickbeard, as if I upgrade to the newest version, it won't start because it thinks something is already running on port 8082. If I roll back to Sickbeard 478, there is no issues.
I am running SABNzbd (8080), Sickbeard (8082) and Couchpotato (5000) on WHS 2003. Any suggestions are appreciated
Great app.
It's looking for the 1080p version. When you look directly at the nzb.su api url that CouchPotato is searching, you can clearly see several 1080p versions, one a director's cut, the other the original cut.
Why does CouchPotato not find it?
Quote:16:59:03 INFO [.movie.sources.theMovieDb] Searching: http://api.themoviedb.org/2.1/Movie.sear...fly+effect
16:59:04 INFO [.movie.sources.theMovieDb] TheMovieDB - Found: [{'year': '2004', 'imdb': 'tt0289879', 'id': 1954, 'name': u'The Butterfly Effect'}, {'year': '2004', 'imdb': 'tt0289879', 'id': 1954, 'name': u'Efeito Borboleta'}, {'year': '2009', 'imdb': 'tt1234541', 'id': 16258, 'name': u'The Butterfly Effect 3: Revelations'}, {'year': '2009', 'imdb': 'tt1234541', 'id': 16258, 'name': u'The Butterfly Effect 3: Revelation'}, {'year': '2006', 'imdb': 'tt0457297', 'id': 14620, 'name': u'The Butterfly Effect 2'}, {'year': '2006', 'imdb': 'tt0457297', 'id': 14620, 'name': u'Butterfly Effect 2, The'}]
16:59:05 INFO [ app.controllers.movie] Adding movie to database: The Butterfly Effect
16:59:05 INFO [ app.controllers.movie] Movie already exists, do update.
16:59:06 INFO [lib.provider.movie.search] Getting extra movie info for The Butterfly Effect.
16:59:07 INFO [ider.yarr.sources.newznab] Searching: http://nzb.su/api?t=movie&imdbid=0289879...1&cat=2040
16:59:07 INFO [ app.lib.cron.eta] Scanning http://videoeta.com/movie/59278.
16:59:09 INFO [pp.lib.provider.yarr.base] Wrong: The.Butterfly.Effect.2004.720p.BluRay.x264-SiNNERS, looking for 1080P
compcentral Wrote:anyone?
What exactly are you trying to post? Links often will be recognized as such. In Tracking-Systems Links are normally treated as SPAM.
acribb Wrote:Great app.
Retention? How old are the files on nzb.su and what is your retention-setting in CP?
krestim Wrote:No, it will not. It runs separately from your browser.
This is a rather interesting problem. I know the behaviour from Unix-System whereas Sickbeard (subsequently the cherrypy-Webserver) has to run with root-priviliges in order to fire up the webserver. Did you try run the executable as Administrator?
I am pretty sure this has to do with framework-change in either the cherrypy or the cheetahtemplates...
Another possibility for you would try running it from the source. You would have to install the Python-Runtime and subsequent dependencies (like cherrypy and cheetahtemplates), but you should be able to run it via a command-line then (that is what I do... I never had problems similiar to yours)
HenryFord Wrote:Retention? How old are the files on nzb.su and what is your retention-setting in CP?
Retention setting was the issue. Thanks for the insight!
acribb Wrote:Retention setting was the issue. Thanks for the insight!
Had the same problem. Thanks for asking.
When I try to download trailers manually it downloads the same trailer for every movie it finds a trailer for, in my case "the imaginarium of doctor parnassus", but I think it choose one of my existing movies.
Have anyone experienced this? Below is the log.
18:01:33 INFO [ app.lib.cron.trailer] Download of
http://trailers.apple.com/movies/sony/th..._h720p.mov finished.
18:00:04 INFO [ app.lib.cron.trailer] Downloading trailer "http://trailers.apple.com/movies/sony/theimaginariumofdoctorparnassus/imaginariumofdrparnassus-tlr_h720p.mov", 79 MB
18:00:02 INFO [ app.lib.cron.trailer] Search for trailer for: Fantastic Mr. Fox (2009)
Im using CP and i gotta say that i love the program..
But i just having some issues with a movie called "House of Bones". If i make search for the movie on the site Nzbmatrix i find the movie.
But somehow CP doesnt download the movie, here is what it shows in the log file
14:13:46 INFO [ider.yarr.sources.newznab] Getting RSS from cache: tt1334536-2040.
14:13:46 INFO [er.yarr.sources.nzbmatrix] Getting RSS from cache: tt1334536-42.
14:13:45 INFO [ider.yarr.sources.newznab] Searching:
http://nzb.su/api?t=movie&imdbid=1334536...1&cat=2040
14:13:36 INFO [er.yarr.sources.nzbmatrix] Searching:
http://rss.nzbmatrix.com/rss.php?usernam...&english=0
14:13:36 INFO [ider.yarr.sources.newznab] Searching:
http://nzb.su/api?t=movie&imdbid=1334536...1&cat=2010
14:13:26 INFO [ app.lib.cron.eta] Searching page:2 VideoETA for House of Bones.
14:13:25 INFO [er.yarr.sources.nzbmatrix] Searching:
14:13:25 INFO [ app.lib.cron.eta] Searching page:1 VideoETA for House of Bones.
14:13:25 INFO [lib.provider.movie.search] Getting extra movie info for House of Bones.
Can someone please tell me why it is not getting the movie ?
