Xeijin Wrote:Hmm, I have my library setup with a folder structure and it still doesn't work for me...
One thing I'm not sure about. CouchPotato asks for the path to where sabnzbd downloads movies AND the path where you want the movies moved.
However, I have Sab directly download movies into my Movies folder so CouchPotato doesnt need to move anything anywhere, but I still want it to rename...I have filled in both fields identically but it doesnt seem to work.
Anyone else in a similar predicament?
Renaming is hit and miss with e. It works sometimes and not others
Indeed like Nick says ...
You need 2 different folders for this to have it work at full capacity/features
I'm currently half way through switching from Windows to Linux XBMC and am not even going to pretend that I know what I am doing.
So, after searching, with no success - and hopefully without sounding like a complete tool (too late!), How do I do a 'Git Pull' properly?
I know how to load Terminal, I have also install the git-core. I need to know the correct commands to compile the CouchPotato code. I have already done
git clone http://github.com/RuudBurger/CouchPotato.git "CouchPotato"
But now I'm stumped.
Linux n00b alert! :p
I tried searching to see if anyone had this issue, but it appears to only be me.
I installed the v20 windows binary the other day and everything is working well except for the "Soon"/"Coming Soon" page. On that page, it always stays blank. Nothing ever gets populated, despite my force refresh and force update release dates attempts.
Just wondering if,
a) Anyone else sees anything on that page at the moment? (I suppose it could be that nothing is coming out soon?)
b) If anyone has experienced this issue.
c) If there is anything specific I should be looking for in the logs?
Thanks,
Mo
DejaVu77 Wrote:I'm currently half way through switching from Windows to Linux XBMC and am not even going to pretend that I know what I am doing.
I know how to load Terminal, I have also install the git-core. I need to know the correct commands to compile the CouchPotato code. I have already done Code:
the folder you were in when you did the git pull is where CP is located at.
Quote:Linux:
Install Python 2.6 or higher
Git clone/extract CP wherever you like
Run "python CouchPotato.py -d" to start in deamon mode
Set your username & password in the settings if you want.
Fill in all the config stuff
did you run "python CouchPotato.py -d" with out the quotes ?
then did you navigate to
http://yourIPhere:5000 ?
once you have it up and running and want CP to start on boot
Quote:Ubuntu (init.d script):
Copy "initd" to /etc/init.d/couchpotato - > "sudo cp initd /etc/init.d/couchpotato"
If you want, change "RUN_AS=root" to another user.
If your CP installation isn't in "/usr/local/sbin/couchpotato/", make sure to change the path in the initd script.
Make executable "sudo chmod a+x /etc/init.d/couchpotato"
Start "sudo /etc/init.d/couchpotato start"
-=Jason=-
Gophermofur Wrote:I tried searching to see if anyone had this issue, but it appears to only be me.
Just wondering if,
Thanks,
Mo
I think I misunderstood the objective of that page. Initially, I thought it was a listing of ALL the upcoming movies either in theatres, or being released on DVD.
However, from what I can gather from the code, it looks like it's a breakdown of the movies you currently want (have added) and what stage the movie is in (will be in theatres within the next 21 days, soon to be released to dvd within the next 42 days, already on DVD). Is that right?
Back from a small vacation and finished with school.
Time to get some coding done!
Gophermofur that is correct. It will be getting a "suggestion"-section too though.
anyone else having problems with it not finding movies anymore? even though there i a 1080p it won't grab it? any ideas?
prince of persia, centurion also the karate kid was another one. just skips it
@ Bigmonty
Please advise in what way you would like to have it running.
So waht kind of set-up ? start at boot ? and so on
As basicly CP is simple to set-up
I keep getting this error no matter what I try:
20:20:55,623 ERROR [app.lib.sabNzbd] Unable to connect to SAB.
Can anyone please help?
HarryRosen
Download fine here, what does the log say about those movies?
daz1uk
Did you fill in the correct login for SAB? CP does have trouble with special characters.
