uglyman Wrote:my version is now reported as version fatal, and it keeps showing update is available. but no matter how many time i update it stays there. is there some way to fix this?
I was getting the same error Uglyman - if I shutdown CouchPotato then did a git pull I was getting conflict errors. Then once I did sort those errors out, it would not start again.
I backed up the config.ini; data.db & cache dir - Deleted the couchpotato folder and checked out the latest version again.
Moved the config.ini; data.db & cache dir back again, and started up the app.
Now all working again.
i've tried that. i even tried starting over agin with a fresh config and data. but i still go the error.
i'm running mac os if that makes a difference
getting the version: fatal after a fresh git pull myself.
everything else seems to be working though.
This is because your git version is out of sync.
Shutdown CP, force a git pull manually, then start CP again.
git disagrees
Quote:[clay@mediasource /mnt/data/apps/CouchPotato]$ sudo -u sabnzbd git pull
Already up-to-date.
I also get the "Update available: update now" message at pretty much all times.
i also get already-up-to-date message from git when i try to update it that way
Ruud,
I currently have couchpotato setup for web accessing and everything is good with that but when I search for movies (multiple movies), the log file indicates there were no search results. I use nzbmatrix and nzbs.org for my provider. Also, no downloads make it to sabnzbd.
Thoughts?
Thanks,
bc
P.S. love the app if I can just get it to woork
Could you guys check out the latest update. Hope to get more info on the "fatal" version.
Flomaster Wrote:CP > Settings > Renaming
Sab > Config > Sorting
-=Jason=-
Thanks Jason. Didnt think i'd have to do both, thought it'd be one or the other.
Can I ask something else please, is there a way of asking CP to search for more than one type of quality? I.e. anything higher than DVD rip?
You do use one or the other.
For quality check Settings >> Quality "Create custom quality.
RuudBurger Wrote:You do use one or the other.
oh right OK thanks for that, I'll use yours within CP then
thanks for that, I'll check out that quality settings screen
i updated to the latest version, and this is the error message in the log
17:36:33 INFO [ app.config.updater] Update available
, error: None
17:36:33 INFO [ app.config.updater] Git version output: fatal: Not a git repository (or any of the parent directories): .git
uglyman Wrote:i updated to the latest version, and this is the error message in the log
, error: None
My log is identical to that.
One thing though on the renamer - kind of a question:
First of all, here are my relative settings before changing anything:
destination = /tank/media/Movies/FeatureFilms
foldernaming = <thename>
With this setting, CP takes the movie and puts it in the movie destination folder, and puts it in its own folder, as in:
/tank/media/Movies/FeatureFilms/The Big Lebowski/The Big Lebowski (1998).1080P.mkv
What I would like to get is:
/tank/media/Movies/FeatureFilms/The Big Lebowski (1998).1080P.mkv
So, to try to reach what I want, I've put 'FeatureFilms' in the folder renaming field in the settings and changed the Movie Destination setting to '/tank/media/Movies', so that when you add it all together, the final destination path will be '/tank/media/Movies/FeatureFilms'. Should this work? So far, renaming hasn't been working, the latest message in the logs is this, but it never moves the file:
'15:29:32 INFO [ app.lib.cron.renamer] Trying to find a home for: The Big Lebowski 1981 1080P.mkv'
Here are my settings after making the change to get what I am trying to get (the final path in green above):
foldernaming = FeatureFilms
