MikeBuzz Wrote:One quick question
I have setup CP to download using sabnzbd, and have the options set that CP moves and renames the download, but on the wanted page the movies are still listed at snatched and not downloaded, any ideas??
couple things to check
your path to SAB is wrong
your api key is wrong
-=Jason=-
Flomaster Wrote:couple things to check
-=Jason=-
if the api key was wrong then the nzb would not get passed from CP to sab would it?? also if the path was wrong then it would not copy from the sab download dir and move it to the correct loaction and rename it would it??
18:10:37 INFO [ app.lib.cron.renamer] Removing dir: C:\Documents and Settings\Michael Busby\My Documents\Downloads\Complete\Movies\Toy.Story.3.2010.PROPER.DVDRiP.XViD-TASTE in download dir.
18:10:37 INFO [ app.lib.cron.renamer] XBMC metainfo for imdbid, tt0435761, generated
18:10:05 INFO [ app.lib.cron.subtitle] Finding subtitles for: C:\Documents and Settings\Michael Busby\My Documents\Movies\Toy Story 3 (2010)
18:10:05 INFO [ app.lib.cron.trailer] Finding trailers for: C:\Documents and Settings\Michael Busby\My Documents\Movies\Toy Story 3 (2010)
18:10:05 INFO [ app.lib.cron.renamer] Moving file "C:\Documents and Settings\Michael Busby\My Documents\Downloads\Complete\Movies\Toy.Story.3.2010.PROPER.DVDRiP.XViD-TASTE\toy.story.3.proper-taste.avi" to C:\Documents and Settings\Michael Busby\My Documents\Movies\Toy Story 3 (2010)\Toy Story 3.avi.
18:10:05 INFO [ app.lib.cron.renamer] Quality Old: 0, New 696.
18:10:05 INFO [ app.lib.cron.renamer] Creating directory C:\Documents and Settings\Michael Busby\My Documents\Movies\Toy Story 3 (2010)
18:10:05 INFO [ app.lib.cron.renamer] Trying to find a home for: toy.story.3.proper-taste.avi
18:10:05 INFO [ app.lib.library] Retrieved metainfo: {u'common': [{u'comment': u'Has audio/video index (6.2 MB)', u'mime type': u'video/x-msvideo', u'image height': 352, u'frame rate': 24.0, u'producer': u'VirtualDubMod 1.5.10.2 (build 2540/release)', u'image width': 640, u'endianness': u'Little endian', u'duration': u'1:42:34', u'bit rate': 941200.0}], u'audio stream': [{u'compression rate': 12.1, u'compression': u'mp3', u'sample rate': 48000.0, u'duration': u'1:42:34', u'bit rate': 126700.0, u'channel': 2}], u'video stream': [{u'image height': 352, u'compression': u'xvid', u'image width': 640, u'bits/pixel': 12, u'duration': u'1:42:34', u'frame rate': 24.0}]}
18:09:51 INFO [ app.lib.library] Found movie via MovieQueue.
but still the movie is listed in snatched and not downloaded
Dude,
You have to click the green 'V' next to the movie....
Vascular Wrote:Dude,
Thanks, thought it was meant to do that its self,
It's purpose is so that you know what has been downloaded. Check the downloaded files and if everything is ok, you click the green 'V'.
When something is wrong with the downloaded movie you click the red 'X' and it will redownload.
No, it should be marked as downloaded.
Will check out why this isn't happening.
wtf? It was searching for 'the sorcerers apprentice' but downloaded 'men in black'
19:30:38 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerers Apprentice TS XViD IMAGiNE, looking for BR-Rip
19:30:38 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerers Apprentice. 2010 TS.XVID-MAGNET, looking for BR-Rip
19:30:38 INFO [pp.lib.provider.yarr.base] Wrong: The.Sorcerers.Apprentice.CAM.XViD-nDn, looking for BR-Rip
19:30:38 INFO [pp.lib.provider.yarr.base] Wrong: The.Sorcerers.Apprentice.2010.R2.LiNE.XviD-CLASSiFiED, looking for BR-Rip
19:30:38 INFO [rovider.yarr.sources.nzbs] Getting RSS from cache: tt0963966-2.
19:30:38 INFO [er.yarr.sources.nzbmatrix] Getting RSS from cache: tt0963966-54.
19:30:37 INFO [rovider.yarr.sources.nzbs] Getting RSS from cache: tt0963966-4.
19:30:37 INFO [er.yarr.sources.nzbmatrix] Getting RSS from cache: tt0963966-42.
19:30:37 INFO [ app.lib.cron.eta] Scanning http://videoeta.com/movie/111323.
19:30:36 INFO [ app.lib.sabNzbd] NZB sent to SAB successfully.
19:30:36 INFO [ app.lib.sabNzbd] URL: http://localhost:8080/sabnzbd/api?apikey=feb57d6786e9a473220ec2f072b96fb&mode=addurl&name=http%3A%2F%2Fnzbmatrix.com%2Fapi-nzb-download.php%3Fid%3D76259%26username%3Dcosmicr%26apikey%3Db2f05a199f4f43ba08d22fa0165ceec&cat=movies
19:30:36 INFO [ app.lib.sabNzbd] Sending 'Men in Black[1997]DvDrip aXXo' to SABnzbd.
19:30:19 INFO [.lib.provider.yarr.search] Checking if http://nzbmatrix.com/api-nzb-download.php?id=769259&username=cosmicr&apikey=b2f05a199f4f43b808d22fa0165ceec is valid.
19:30:09 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerer's Apprentice TS XViD IMAGiNE, looking for DVD-Rip
19:30:09 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerer's Apprentice TS XviD FLAWL3SS, looking for DVD-Rip
19:30:09 INFO [pp.lib.provider.yarr.base] NZB contains ignored word french: The Sorcerers Apprentice 2010 FRENCH TS MD XviD BUBULLE2
19:30:09 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerers Apprentice 2010 TS XVID MAGNET, looking for DVD-Rip
19:30:09 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerers Apprentice CAM XViD nDn, looking for DVD-Rip
19:30:09 INFO [pp.lib.provider.yarr.base] Wrong: The Sorcerers Apprentice New Audio Prism, looking for DVD-Rip
19:30:09 INFO [pp.lib.provider.yarr.base] NZB contains ignored word french: The Sorcerers Apprentice READNFO FRENCH TS LD XViD ZEDZED
It's a wrong imdbid on nzbmatrix side.
Ruud,
If CP has found a movie and it downloaded correctly it should put the movie in the category downloaded? That has never worked for me.
Everything works, from downloading to renaming and finding subs but it always stays in snatched until i click the green 'v'.
Yeah it should, but it's broken right now..
It's on my todo list, but working on something else at the moment
I'm probably doing it wrong, but say I "want" a movie and give it a 720P quality setting. I see in the logs that after it goes through all the choices and can't find any, it waits. Would it be possible to have couchpotato start looking for BETTER quality settings, like 1080p? I see it skip over 1080p versions, even when it has found nothing else. I'm thinking something like a "min" and "max" setting, and have CP get any of them it finds in that range. Setting min==max would indicate I want ONLY that quality.
Or have I just committed some user-error?
campbellm Wrote:I'm probably doing it wrong, but say I "want" a movie and give it a 720P quality setting. I see in the logs that after it goes through all the choices and can't find any, it waits. Would it be possible to have couchpotato start looking for BETTER quality settings, like 1080p? I see it skip over 1080p versions, even when it has found nothing else. I'm thinking something like a "min" and "max" setting, and have CP get any of them it finds in that range. Setting min==max would indicate I want ONLY that quality.
yeah this was the most confusing part about CP for me actually. Its really the wording - you assume that 'custom quality' is for something not listed in the default list, but in fact its more like setting a quality preference list.
if you select one of the default qualities, it will only get that quality.
So you have to make a custom quality (I think these should be called quality profiles to clear up some confusion). In custom qualities you can set it to get many different qualities, and either keep looking if its a low quality, or stop after its found a high quality.
In fact, I reckon it should be compulsory to setup a 'custom quality' at first time setup, to help avoid confusion.
cosmicr Wrote:yeah this was the most confusing part about CP for me actually. Its really the wording - you assume that 'custom quality' is for something not listed in the default list, but in fact its more like setting a quality preference list.
Thanks Ruud and cosmicr - I'll give that a whirl. I saw the "custome quality" thing but was having an old-guy moment trying to figure it out.
