Full Version: svn: No passtrough if using navigation sounds
Just upgraded my htpc to lucid and therefore jumped on the svn(31181) bandwagon again.
The problem seems to be that the navigation sounds are blocking the passtrough device.
If i disable navi sound i can use dts and such.
23:12:34 T:2730515312 M:3091496960   ERROR: Initialize - failed to open custom device iec958:AES0=0x6,AES1=0x82,AES2=0x0,AES3=0x2 (error:Device or resource busy), retry with default iec958
23:12:34 T:2730515312 M:3091496960   ERROR: Initialize - pcm_open_lconf, alsa error: -16 - Device or resource busy
23:12:34 T:2730515312 M:3091496960   DEBUG: SetActiveDevice - SetActiveDevice from 2 to 1
23:12:34 T:2730515312 M:3091496960   DEBUG: RemoveActiveDevice - Removing device 2
Pastebin link
http://pastebin.com/2ay5QMc3
Any suggestions on this, i found a few similar issues from 2009, but nothing like this.
bump, would be glad for any suggestions for where to look.
I know this whole SPDIF / hdmi issue is pretty normal but they can all be easly fixed. But this problem i havent found any answears to.
"Analog" sound works as normal with navi btw
