I'm pretty new to xbmc and am trying to install it on my windows 7 64bit machine. I have the latest stable xbmc (9.11) and the latest aeon stark.
Everything works great until the library scan part. When i try to "set the content" on my movie folder and click ok nothing happens. When i press "Set content" again the changes i made are gone.
I have tried to uninstall everything and install it again in case something was corrupt but it didn't help :/
Install the 6/16 nightly build and have it scan for new content. I had similar issues with 9.11 and a March nightly build but the 6/16 has run great.
I tried the 6/16 build and a couple of others but still won't work. When trying it in confluence i get a slightly different result though. All my settings get saved except "run automated scan". It feels like i'm doing something wrong or missing something. Here is a clip of what happens:
http://screenr.com/fSm
Have you tried a different scraper?
Yup, and i have tried scraping TV.
The r31275 build fixed most scanning issues for me.
prince1142003 Wrote:The r31275 build fixed most scanning issues for me.
I've tried that build.
Quote:Are you sure your permissions are ok, ie that XBMC is able to save any settings?
Are you running in portable mode, where is your userdata stored?
http://wiki.xbmc.org/index.php?title...data_stored.3F
I'm definitely not sure all permissions are in order. I have tried both portable mode and normal. And "run as administrator". And turned of UAC (read in another thread that it solved a similar problem.
I am also getting the same problem... I reinstalled every thing and got this, will give a few more things a try and will let everyone know
I got it working with the latest release (r31657).
