Full Version: Speed up scrolling in big collections
Hello
I want to speed up the scrolling in big music/video collection.
I found an old thread (http://forum.xbmc.org/showthread.php?tid=65376)
but it seems that the syntax have changed.
What do i have to add in (mymusicnav.xmx,myvideonav.xml) to disable fanart and thumbs changing during scrolling?
thx
depending on which revision of xbmc you are using,
you could upgrade to the svn version of Transparency!
check this post for compatible versions:
http://forum.xbmc.org/showthread.php?tid=70134
ah ok. i use XBMC PRE-10.5r31226 and i downloaded the latest Transparency! from SVN yesterday.
