Full Version: edit home screen
hi fellas can someone please tell me how can i add something like "music video" to the home screen
thanks in advance
start editing 720p\home.xml at about line 690 is the main menu items
thanks for you help, but how do i know where the 690 line is do i have to count every line inside home.xml?
again thanks
get an xml editor.
notepad++
Are you looking to point it to a certain folder or source?
mfwilli Wrote:Are you looking to point it to a certain folder or source?
yeah thas what i am trying to do
thanks
mata7 Wrote:thanks for you help, but how do i know where the 690 line is do i have to count every line inside home.xml?again thanks
If you are Linux user and using vi/vim as your editor, then follow this sequence:
Esc > Confusedet nu <enter>
(i.e hit Esc key, then type Confusedet nu)
to display the line number. and doing this:
Esc > :690 <enter>
will take you to 690th line. Have fun with vi Nod
