Full Version: [Mod] Wide List View
Xperience is really one of, if not the, best skins available imo. I normally prefer utilitarian list views, and the tri-panel view is great. Unfortunately, a pet peeve of mine is scrolling titles. So i spent tonight making a wide list view. Thanks to Team Blackbolt for their unprecedented code organization. It made adding a view and view options super simple (its mostly just a modified tri panel view). I was only able to test this on a laptop that is not 16:9, but i assume everything will look good thanks to xbmc's rendering. Enough dribble, here are the screen shots and download info:
[Edit] This mod was done using Xperience 1.0
[Edit #2] - I just realized the stage is hidden. Its because i used 59 for a control id that was already used (and was part of the hidden stage visible condition). You can fix it by editing the Includes_Window-Contents.xml "CommonStage" include. Unfortunately, i dont know what control has id 59, that is now going to show the stage. Can anyone from teamblackbolt let me know if there is an open id for me to use?
Download here (instructions included):
http://www.mediafire.com/file/mknqjddzly...st_Mod.zip
Very nice mod that wouldn't look out of place in the official Xperience.
Exactly what I was thinking Hitcher.
Any updates to the alignment issues I sent you a pm about? Also, Please post any further mods here http://forum.xbmc.org/showthread.php?tid=70165
pm sent
XBMCG33K Wrote:Any updates to the alignment issues I sent you a pm about? Also, Please post any further mods here http://forum.xbmc.org/showthread.php?tid=70165
If you meant the unwatched tag, I got that fixed and have this mod merged on my end....
mcborzu Wrote:If you meant the unwatched tag, I got that fixed and have this mod merged on my end....
I really want this in 1.1 mcborzu, can you pm me the fixed files needed to merge?
