Hey man... Just rounding up the stuff we talked about and earlier requests...
Music Videos
#1 Make the cool display/fade out thing for the info screen work
#2 I don't think its necessary to extend the dark rectangle to the whole width of the screen; maybe do something wrapped up and smaller (info screen, that is).
Music
#3 Artist info on Music thumbnail view (in top center). You are handling the top space much better in movie welo and poster view.
#4 Looks like Music thumbnail view is a file mode view, we'd like to see "music" in the top left corner.
#5 For albums with multiple disks, infos on the disk number in Songs view would be nice. (Request Post #77).
#6 The clock moves in and out in the wrong direction when disabling and enabling the info screen on fullscreen music playback.
Movies
#7 Make long movie titles scrolling in all views.
#8 We have trailers for some movies. Some info on this in welo view would be cool. The thing you did for standard poster view would be perfect.
#9 Playback info should be as we discussed, top part as is, bottom part from pause screen minus one of the posters.
#10 I know you use movie sets, please find a way to make them look nicer. Also, if possible, could you do an (optional) overlay such as this for sets?
Of course, you would have to make it look nicer, its just an idea. :-)
TV Shows
#11 We don't like star ratings, please give us the option to have numeric ratings as well. Combination with the watched icons as discussed would be perfect.
#12 For TV-Shows, instead of having two lines for total number of episodes and watched, integrate to one: watched: xxx of yyy or xxx / yyy
#13 If possible in any way, in the first tv-show-level (where all tv-shows are displayed), add the number of seasons, suggestion:
Watched: 123/256 Episodes in 7 Seasons
#14 Info screen for tv-show playback should be the same as for movie playback.
#15 In the attached pic, is this supposed to be like this or is the background rectangle slightly offset?
http://files.x0n.de/xbmc/tv_view.png
General:
#16 Make the skin more compatible for different languages, there are a lot of fields where you just hardcoded english text instead of using IDs. If it helps you find those places, I'll see if I can make you a list of places.
#17 RSS-Feeds are not working. I think you have figured it out already. :-)
#18 Add a Button for settings to shutdown menu, I've found that to be practical in other skins.
#19 Add an option to remove Home and Settings button in main menu, Home because I want to try if I can manage without it and save some space. Settings button should only be removable in combination with #16, otherwise things could get messy. :-)
#20 The Music Video button on homescreen is still missing. :-)
- Also, good work. Keep it up. Thanks.
