I've tried SAK add-on, noticed that it installs a HUGE amount of extra stuff, and decided to remove it. Used the deinstall.sh script provided. Guess what?
IT REMOVED EVERYTHING, including: xbmc, telnet, ftp, even ssh.
I wonder why, and would someone be willing to fix this? Luckily, I had a system backup...
heraldo Wrote:Hi,
This is the list of software that will be removed ...
apt-get remove --purge mencoder
apt-get remove --purge netcat original-awk dvdauthor mkisofs gddrescue
apt-get remove --purge dvd+rw-tools lsdvd dvdbackup
apt-get remove --purge submux-dvd subtitleripper transcode mjpegtools libdvdcss2
apt-get remove --purge liba52-0.7.4 libfaac0 libmp3lame0 libmp4v2-0 libogg0 libsamplerate0 libx264-85 libxvidcore4
apt-get remove --purge libbz2-1.0 libgcc1 libstdc++6 zlib1g
apt-get remove --purge build-essential lynx libc6-dev libssl-dev libgl1-mesa-dev libqt4-dev
I DO NOT SEE FTP OR SSH OR XBMC OR TELNET ... ?
Hi, I have installed as per your instructions and when I go to Transcode DVD i get an error saying "DVD Transcoding could not be started" I have enabled it in the configurations menu but for some reason i get this error. any help on this would be much appreciated.
I'm running linux mint debian if that is of any help.
Cheers
Trying to troubleshoot to see why I can transcode some DVD's and others not so much. If I run check-mkv.sh, I get...
script : check-mkv.sh
version : 0.6.20 [swiss-army-knife addon] [13.06.2011]
copyright : © <2010-2011> <
[email protected]>
changed to /home/brad/.xbmc/addons/script.video.swiss.army.knife/shell-linux
[: 166: 0: unexpected operator
[: 172: 0: unexpected operator
----------------------- script rc=0 -----------------------------
Can anyone speak as to what those operator errors mean?
This is a pretty old thread, so I'm not sure if anyone is listening...
But is there any news on a release that will work in Gotham?
I have looked everywhere, and it looks like Swiss Army Knife is the ONLY add-on that will rip-transcode movies from within XBMC, but Gotham lists the add-on as incompatible.
Thanks for any info
