2010-06-29, 22:55
2010-07-02, 03:34
Sorry, no screen shot....
Music/Artist/Artist Info - Info List view
Artist biography doesn't seem to scroll.
2010-07-02, 05:12
JDizzy Wrote:Sorry, no screen shot....
Nice find. Fixed for next update.
2010-07-02, 23:48
Just downloaded the new version.
When you goto recently added movies, you can change the views so far, then it gets stuck on one view.
You have two movie posters in a line and fan art at the back. I shall try the same on the other options to see if it happens again.
** Update **
Yeah it has done it on episode panel view as well, when you try going up it will not show the menu.
Regards
Mark
** Update **
Regards
Mark
2010-07-03, 04:11
MarkTaunton Wrote:Just downloaded the new version.
** Update **
Regards
Mark
Screenshot Mark, come on you know the drill.
2010-07-03, 05:33
Remember, screenshots only work if it's a cosmetic problem...you can take a million screenshots and it's not going to help you solve the problem MarkTauton has.
2010-07-03, 07:50
when the skin is loading e.g going through the scan of new titles
for some reason it comes up with recentlyadded.ply or something like that script failed as well.
Hang on guys
Hang on guys
2010-07-03, 08:37
I'm not sure how long this will take to process
http://www.youtube.com/watch?v=PeBiYgHU1Ns
Hopefully it turns out ok, this was just a quick attempt at some new software.
2010-07-03, 12:57
MarkTaunton Wrote:I'm not sure how long this will take to process
Great vid Mark. Try using the newest SVN. I am on it now and everything works fine.
2010-07-04, 04:30
TV Series/Large Eps.
I think scrolling problem. It will scroll through plot 1 time, then just sit there.
(It doesn't seem to recycle back to top again).
2010-07-04, 04:48
JDizzy Wrote:TV Series/Large Eps.
I am using the same code as confluence, I have no clue what causes this, I experience it too.
2010-07-04, 18:11
igotdvds Wrote:I am using the same code as confluence, I have no clue what causes this, I experience it too.
?? - Is there another part (like movies or music artist info (after fix)) where the scrolling does work correctly? If so, what is different.... or copy that code and plop it into TV section...
I'm sure you already been there though... hmmm
2010-07-07, 18:07
Anyone not seeing logos in TV area (Clear art view, top level)?
I am using last nights SVN and 1.04 skin.shade.
I thought in pre-merge they were working before....
2010-07-07, 18:25
JDizzy Wrote:Anyone not seeing logos in TV area (Clear art view, top level)?
I just checked and they work for me.
2010-07-08, 02:25
igotdvds Wrote:I just checked and they work for me.
No dice...
Updated SVN to 31648, running on AppleTV (osx), reinstalled Shade 1.04, tried.
All I get on TV Clearart view is fanart background and black area at bottom of screen where Logo should be. Logo isn't showing on movie info section either.
Maybe I'll wait for next 1.05 update and see if shows up. Could be an Apple thing, dunno.
Thanks for help!
