Full Version: No network access on Acer Revo AR1600-U910H
Hi, I have been using XBMC on old xboxes for a few years.
Just purchased an acer aspire AR1600-U910H and installed per the instructions here http://forum.xbmc.org/showthread.php?tid=53888
There was no REVOBOOT in my bios to disable
Bios Version=P01-A4
Bios Date 11/03/2009
XBMC loads but I have no network connection
I downloaded and reinstalled with the latest release of xbmc 9.11 and still no network access
Would this be a network driver issue?
Can you drop to a terminal (ctrl+alt+F1) and post the output of
ifconfig
You can use "exit" and then ctrl+alt+F7 to return to XBMC.
Here is what is displayed and is what I entered for network settings during install.
Link encap:Ethernet HWaddr 90:fb:a6:87:37:5d
inet addr:10.0.1.64 Bcast:10.0.1.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 erroes:0 dropped:0 overruns:0 frame:0
TX packets:0 erroes:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0B) TX bytes:0 (0.0B)
Interrupt:23 Base address:0xe000
Thanks for the help
