2010-07-01, 20:46
This is under current SVN r31542. I have a specific h264 encoded video file that will not play utilizing VDPAU decoding, all other files do play using VDPAU.
My log file is located here: http://pastebin.ca/1892947.
Some relevant pieces of the log are
Thank you.
14:20:16 T:2990324592 M:1602789376 INFO: ffmpeg[B23CBB70]: Input #0, matroska, from 'smb://blakula/zpool1/dump/Jason And The Argonauts 1963 1080p BluRay x264 CiNEFiLE/Jason.And.The.Argonauts.1963.1080p.BluRay.x264-CiNEFiLE.mkv':
14:20:16 T:2990324592 M:1602789376 INFO: ffmpeg[B23CBB70]: Duration: 01:43:54.21, start: 0.000000, bitrate: 10943 kb/s
14:20:16 T:2990324592 M:1602789376 INFO: ffmpeg[B23CBB70]: Stream #0.0(eng): Video: h264, yuv420p, 1808x1080, PAR 1:1 DAR 226:135, 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
14:20:16 T:2990324592 M:1602789376 INFO: ffmpeg[B23CBB70]: Stream #0.1(eng): Audio: dca, 48000 Hz, 6 channels, s16
14:20:16 T:2990324592 M:1602789376 INFO: ffmpeg[B23CBB70]: Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
14:20:16 T:2990324592 M:1602789376 NOTICE: Opening video stream: 0 source: 256
14:20:16 T:2990324592 M:1602789376 NOTICE: Creating video codec with codec id: 28
14:20:16 T:2990324592 M:1602789376 DEBUG: CDVDFactoryCodec: compiled in hardware support: CrystalHD:no OpenMax:no VDPAU:yes VAAPI:no
14:20:16 T:2990324592 M:1602789376 DEBUG: FactoryCodec - Video: - Opening
14:20:16 T:2990324592 M:1602789376 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1808x1080, 28)
14:20:16 T:2990324592 M:1602535424 NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
14:20:16 T:2990324592 M:1602535424 NOTICE: VDPAU Decoder capabilities:
14:20:16 T:2990324592 M:1602535424 NOTICE: name level macbs width height
14:20:16 T:2990324592 M:1602535424 NOTICE: ------------------------------------
14:20:16 T:2990324592 M:1602535424 NOTICE: MPEG1 0 8192 2048 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: MPEG2_SIMPLE 3 8192 2048 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: MPEG2_MAIN 3 8192 2048 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: H264_MAIN 41 8190 2032 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: H264_HIGH 41 8190 2032 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: VC1_SIMPLE 1 8190 2048 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: VC1_MAIN 2 8190 2048 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: VC1_ADVANCED 4 8190 2048 2048
14:20:16 T:2990324592 M:1602535424 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_NOISE_REDUCTION
14:20:16 T:2990324592 M:1602535424 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_SHARPNESS
14:20:16 T:2990324592 M:1602535424 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL
14:20:16 T:2990324592 M:1602535424 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL_SPATIAL
14:20:16 T:2990324592 M:1602535424 NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_INVERSE_TELECINE
14:20:16 T:2990324592 M:1602535424 ERROR: (VDPAU) Error: A catch-all error, used when no other error code applies.(25) checking for decoder support
14:20:16 T:2990324592 M:1602646016 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
14:20:16 T:2990324592 M:1602646016 NOTICE: (VDPAU) Close
14:20:16 T:2990324592 M:1602646016 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
14:20:16 T:2990324592 M:1602625536 DEBUG: FactoryCodec - Video: ff-h264 - Opened
Thank you.
